My wife and I are thinking of purchasing a small travel trailer. Most likely the TAB 400. We would need a new tow vehicle so I am trying to figure out what the best all around tow vehicle is for long trips. It will also be my everyday driver when not camping. I dont commute as I work part time from home. Originally looked at the BMW X5 but I am thinking that a truck chassis may be better long term?? The number of choices seem overwhelming so I wanted to ask the community for ideas.
2020 Jeep Cherokee Trailhawk Elite
Looking for a TT
0 ·
2017 Highlander Limited
If the Trailhawk has a tow pkg, you may not need a new tow vehicle. Please get back to us with those answers and the group will be able to help direct you-
Looking for a TT
I'm assuming you are searching for a great balance of tow vehicle to trailer somewhere between minimal and overkill. That balance feels different for everyone. So, good luck with your quest. Enjoy the challenge. It's all part of the adventure!
Looking for a TT
2020 Audi SQ5
Tacoma and some others dropped V6 for a smaller 2024 V4 with turbo. We avoided costly and less hardy Turbo and looked for a 2023 3.5L V6 for towing.
Few if any manual transmissions available. Auto gear programming may be totally unsuited to towing unless has a Tow Mode or you reprogram the computer to maintain higher rpms.
Factory 5th gear at 35mph 1100 rpm and 6th overdrive at 43mph 980 rpm getting on highway is unacceptable!
A Scangauge III on dash helps monitor torque and fluids temperatures.
Few if any single cabs available. Dual cab lengthens turning radius dramatically. I can no longer make needed turns in drive or Uturn the camper.
Few if any "tow ready" trucks come with a Brake Controller. Have to add one.
Tailgate will not clear center mounted jacks. Side jack or removable trailer Jack needed.
Our new 2023 Tacoma handles and tows well. Need towing mirrors. Old V4 Tacoma was not up to towing on hills or altitude.
Looking for a TT
If the smaller V4 engine on a 2024 10 speed is more satisfying than the 2023 V6 6 speed, that just proves appropriate gear selection is the key which you can manipulate manually.
Good info on the rationale for manual override when towing here:
https://www.tacomaworld.com/threads/the-tacoma-towing-bible.4031/page-100#post-29733669
Have to say after a lifetime of MT I hate being forced into an automatic... which doesn't even tell you which gear is active!
Scangauge III is a critical tool to driving this thing and selection of the necessary override gears.
