Source for the "pocket" screw hardware used for cabinetry?
I am looking to see if I can get some of the pocket hardware that nuCamp uses for their joinery. I have googled all types of pocket fasteners, screws, inserts, etc. and I just can't seem to find anything at all that they are using. Before I reach out to the factory, anyone have a link or am I missing what that fastening system is called?
2022 T@B 400 Boondock
South Jersey
South Jersey
The "square head" screws are called Robertson screws. I know that owners have discussed this before, but I haven't been able to find the threads. I am not "hardware proficient" but this is a search for Robertson wood screws with sources.Amazon calls them "square drive" screws.
Try looking for Kreg brand. They make the pocket hole jigs and screws. I usually find them at Lowe’s and Home Depot. Available online at other retailers too.
Homeport - Virginia Beach, VA
I thought you may be looking for these.
https://woodlandairstreamparts.com/cdn/shop/files/airstream382057_2_f4c351d3-1335-4605-a164-283241c42c64.jpg?v=1692095169&width=1445
https://woodlandairstreamparts.com/products/airstream-8mm-furniture-and-panel-knockdown-382057
They have caps also.
There should be a more direct source...
Aha! Today I learned I know even less than I thought about hardware!
Check out McMaster-Carr Supply Co for Robertson screws.
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
