Howdy! I sent a request to Nucamp support and they directed me to my dealer (who I have e-mailed). They are 2.5 hours away, so I thought I'd ask for suggestions here. Our door takes a good nudge to close in the closed-closed position. This feels ok to me. At the bottom of the door, the left side (facing) doesn't quite close enough--and you can see a bit of light coming through on the inside. No water is getting as far as I can tell. I don't see any way of adjusting this without giving it the old bend-a-roosky (bending in the bottom left side of the door a bit). But with this being new and under warranty, I don't really want to do it. I don't see any issues with the seals. The sealant they put in the bottom corners is a little sloppy, but doesn't seem to be affecting closure. I used a straight edge and can't really figure out the issue. Anybody have an ideas? I did search and found some threads on bending adjustments for doors bowed in the middle (and not closing well), but nothing just at the bottom. BTW, I could just add a bit of weather stripping at the bottom to block the gap, but...
My ‘21 Tab 320 had issues with water leakage in part because of poor sealing done around the sides of the door. I would definitely recommend having this looked and fixed under warranty. The door definitely should not be that out of alignment.
_____________________________________________________ Ken / 2023 Tab 400 “La Bolita” (31,000+ miles) / 2024 Toyota Sequoia
