My control panel is dead, backlit no normal screen. At first it was totally black, but now just backlit. Most things I read about that relate to the thermal fuse on the 3010. But I cannot find anything whether or not the 3020 has a thermal fuse. There is an item that appears to be a resistor under the one green fuse box, so I don't believe that is the same as the 3020. I have a new main board coming, and Truma already had me change the control panel which was no help. Any insight would be appreciated. 3020 picture attached.
when did this happen (sequence of events?)
2015 Audi Q7 TDI
Northern Ohio
edit - oh, I read poorly. You’re working with them already. I’d stick with it. Matalyn Prusinski was the tech who helped me.
2015 Audi Q7 TDI
Northern Ohio
Question:
Is the 3020 Control PCB picture you posted your actual units PCB or a web-sourced PCB picture?
Comments:
All web-sourced 3020 Control PCB pictures appear to be the same version as your image.
These boards (PCB version) do not appear to have a Thermal Fuse component installed/included on the PCB.
On your picture and web-sourced images the Item Under the Green Fuse Holder is a diode.
Sounds like Alde/Truma have been helpful on troubleshooting and parts.
