2021 tab boondock having Alde issues.
It was 17F last night.
Is it normal for gas to start up ( clunk rumble and spin up Alde "fan" to 4300 rpm) but then shut down after only a minute or two? At 6500 ft ASL we tried both Mountain and 'flatland" settings.
Expected to freeze last night and gratified to find the frequent restarts kept us toasty.
We were on 2kw Electric to heat up and 1kw overnight previously. But Electric stopped heating or spinning up Alde fan suddenly mid meal. Now nothing makes it work. Have to tear apart bed and check glass fuses.
Where do error codes show up? See none as depicted in user manual. The mountain/elevation symbol is flashing when we grey out the screen using right display button. The time (12:00) since we kept resetting all power is flashing. Do these have relevance?
0 ·
-=- High Altitude Mode runs the Combustion Fan (also called exhaust fan, fan) at a higher
RPM to provide more oxygen for a cleaner/hotter burn. Usage at 6,000 feet is recommended.
-=- When on Propane Only; a low battery can cause the unit to cycle the fan (burner) on/off. This
happens on my unit at a battery voltage above the Alde 'low battery cut-off'.
When on Propane Only consider turning off as many 12VDC loads as possible to reduce
battery voltage drop.
- Switched to propane and only short audible operation but temperature is maintained.
My first hunch would be that shore power failed or the AC breaker for the Alde system tripped. As pointed out above, the Alde gas burner only runs for a couple of minutes if it maintains temperature. There are two different sources of noise, one is the circulation pump that runs in intervals in both modes, and the exhaust fan when the propane burner is on.
Does flashing symbol connote an error?
Two of four harvest hosts crossing the country had electric hookups so we ran at 2kw to warm up and 1kw 50F overnight. Going to Alde Service Menu shows the glycol Temps which I monitor. All good.
We used gas two nights but only for an initial warmup, not all night. Maybe it short cycled but I should have noticed with my oversensitive hearing. (Hyperacusis, no sound however small is escapable.)
We were on electric in the snow in SD and MT set at 50F all day. During dinner it got cold and we realized glycol Temps had cooled. Unable to get electric heat to budge glycol after that for an hour. , Went to gas and encountered shutoff without restart several times. Purged system, barely cracked gas valve, ran stove, and ensured gas going to Alde.
Then it kept short cycling which I had not experienced in the past. After bringing a mountain of blankets, winter sleeping bag, and down jackets inside our unroomy tab for the night we found the short cycling kept the glycol hot enough to be cosy, although it fluctuated a lot.
I've never tried gas plus electric til now but spent two hours checking every setting permutation and reset I could come up with.
Priority both ways. So we seem to have gas but I'm worried whether it's running correctly, and definitely no electric. Not a fuse or power issue. Bought a second tank today and ratchet strapped to the boxes.
Also an electric ceramic disc heater for backup.
We have weeks of boondocking planned and I'm wondering whether we have a circuit board issue.
120v power symbol yes
Circ pump symbol yes
House symbol yes
Last tank fill Newfoundland Can.
We haven't been above 4000 ft since 2021* so perhaps that relates to short cycling. But another cozy night of gas heat so we'll live with it .
We fled 17F Montana night for a balmy 29F SD night with 54F day. Delightful
Definitely no 120v heat. I have a call into Alde.
Thanks.
(*2021 inaugural November trip West with no gas at all as we did not know the secret sauce of cracking the valve barely.)
