2023 TAB 400 solar upgrade
Can I connect the factory 14/3 ac wire a Victron multiplus 2 3000 or to I need to upgrade to 10/3 wire?
  • elbolilloelbolillo Member Posts: 533
    I’m not sure why you named this thread ‘solar upgrade’. However, in answer to your question, the 10/2 wire coming from the shore power plug gets connected into the Victron and then you will need 10/2 wire to connect from the Victron into the distribution panel.
  • HammickHammick Member Posts: 80
    Don't even think about using the 14/2 wire to power the Multiplus.  Running the microwave or AC would likely overheat the wire and potentially cause a fire.  Your wire from the shore power input to the WYCO convert should be 10/2 (30 amp).  You will need to find a way to extend that wire to the Multiplus or run a new 10/2 wire.
    FYI the price of 10/2 at Lowes and Home Depot is insane.  Best to buy it by the foot at an electrical supply place.  I bought 25' yesterday at $1 per foot for my inverter upgrade on our AVIA.
