Undersize charging wire, WFCO to batteries, Upgrading to lithium in 2019 T@B 400
In my 2019 T@B400 (no solar) I just replaced the two original AGM Harris Batteries with a single Battle Born 100ah lithium. The original charger, 55 amp WFCO 8955PEC, isn't lithium compatible. Battle Born Rep offered a 55 amp Progressive Dynamics 4655V to convert the WFCO to Lithium capable. My problem was the factory wire between the WFCO and the AGMs is 8 gauge and runs 22 feet long behind cabinets and under the bathroom floor. Both Battle Born and nuCamp agreed that is undersized for that distance for a 55 amp charger. I don't know why it also isn't undersized for the existing AGM batteries. Though I know of no problem it caused in the 4 1/2 years I have lives in my T@B. Instead of running 22 feet of 4 gauge wire I bought a PD9345 "deck mounted" charger, installing it right next to the new lithium battery. Only 2 feet of cable required. Also I disabled the charging feature on the WFCO by removing a single power wire for the panel breaker. FYI, I also installed a shunt to monitor the lithium battery and an ANL fuse on the battery's hot wire. Progressive Dynamics said to run a dedicated ground wire from battery-negative to chassis-ground. The existing battery compartment vent hole provided a passage through the floor. Since Lithium doesn't require venting for gas I eliminated the battery encasement cover.
2019 T@B400
Southern California
Full-timer since 2019
  • RMoRMo Member Posts: 162
    Thanks for the overview.  I’m considering something similar and have a few questions.  How difficult was it to remove the black cover?  Any tricks?  What are the dimensions of the space that remains after you remove the cover?  Any lessons learned that might be useful?
    2019 T@B 400 (for sale)
    2017 Highlander Limited
  • jimcennamejimcenname Member Posts: 296
    I removed the lower third of the bed platform. Then unscrewed about 10 screws holding the cover in place. I lifted the cover on the outbound side, disconnected the battery cables and feed them through the hole on the side of the cover. Then the cover lifted off. The AGM batteries weigh about 60 lb each. I flipped them on their side and pushed them out the cargo access door. The roughly 11 X 8 inch space of one AGM battery was used for the new charger, shunt and fuse. I gained no space but lost about 90 pounds. I'll have to see how much the tongue weight changed.
    2019 T@B400
    Southern California
    Did you use the original pos and neg leads from the battery, or replace them with larger gauge wires?
    thanks,
    They were 4 gauge cables about 2 feet long. That's sufficient to handle the current from the charger, which is at the end of a 2-foot long 4 gauge cable. They connect at the existing distribution studs.
    2019 T@B400
    Southern California
  • BinghiBinghi Member Posts: 365
    Nice mod, @jimcenname - I’m upgrading my 2021 400 to lithium and thinking of doing something similar.
    A few questions:
    How come you used the PD 9345 instead of the PD 9360? Wouldn’t the 9360 charge the battery faster?
    It looks like you put in an AC outlet to power the converter. Did you create a dedicated circuit for the outlet by running the outlet cable back to the power center and installing another circuit breaker? What gauge cable did you use?
    Did you keep the OEM inverter?
    Thanks!
  • SLJSLJ Member Posts: 608
    When I installed my lithium batteries I also put in a Victron Smart Charger for charging them when on shore power. When on shore power I let my non-lithium WFCO (2021) supply DC and just shut off my batteries. If they need charging I switch on the Victron and let them charge. When I unplug from shore power I just turn them back on. I trust the Victron charger way more than any WFCO.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
  • tphaggertytphaggerty Member Posts: 57
    I have a 2018 400 that looks very similar to your pictures with the battery located under the bed. I'm having trouble understanding the "22 ft" wire run. In my Tab, the wire from the WFCO (now upgraded to a Progressive Dynamics) runs from the converter directly under the bed (in a subfloor) to that back compartment, basically the width of the trailer, so maybe 10 feet.
    I have 3 Renogy 100ah Lithium batteries in that space now. While I too have concerns about that wire being undersized, it doesn't seem to be an issue so far. I have felt the charge wire while charging at 55 amps and it hasn't been hot at all. I plan to install a larger gauge wire in the spring, but not sure where the 22 ft measurement is from/to.
    2019 Honda Ridgeline RTL TV
    Poughquag, NY
    edited January 25
    When choosing an appropriate wire gauge you’ll want to consider the entire circuit length - negative from the battery and positive back to the battery.  Given this is a 22 foot run it would mean 11 feet each way.
    My WFCO is under the dining bench seat by the door, the cable from the WFCO's 55 amp non lithium charger goes across the trailer to the space under the other bench seat then to the rear via the spacer under the shower and Alde compartment then back to the other side of the trailer to the battery. 22 feet of wire. That's a long run for 12 volts/55amps. Using a 45 amp charger reduces the gage wire requirement. I rarely boondock (at most overnight at a Cracker Barrel) so I don't do a lot of demanding charging. If the the battery is at 60 percent state of charge it takes about 30-45 minutes to get it back to 100 percent with the 45 amp charger. BTW the battery/charger area is not well vented so when doing that kind of charging it gets to 95-100 degrees briefly. I may install a vent and fan. For comparison, my Alde compartment is ~105 degrees right now, 50 degrees outside.
    2019 T@B400
    Southern California
    A few questions:
    How come you use d the PD 9345 instead of the PD 9360? Wouldn’t the 9360 charge the battery faster?
    It looks like you put in an AC outlet to power the converter. Did you create a dedicated circuit for the outlet by running the outlet cable back to th usinge power center and installing another circuit breaker? What gauge cable did you use?
    Thanks!
    Using Romex I did install an outlet by the new charger. I tapped into the circuit that powers the outlet by the kitchen sink and runs to the foot of the bed, so I don't use my Keurig on that outlet when I have to charge a lot. I don't have an inverter. I don't have solar. I don't boondock. I rarely deep dishcharge and recharge. I don't need the extra charging speed of a 60 amp charger and didn't want to deal with the bigger-yet gage cables.
    2019 T@B400
    Southern California
    Got it, thanks a lot.
  • qhumberdqhumberd Member Posts: 536
    Thanks for the inspiration @jimcenname! I just checked my 2019 AGMs in my 400 and they are definitely not able to keep up with even an overnight on the road. After a lot of scanning threads I finally decided on the LiTime since the sale was too good to pass up.
    LiTime 12V 230Ah Plus Deep Cycle LiFePO4 Battery with Low-Temp Protection. This single 12 V is small enough to fit the space of the Harris AGMS with a little to spare. I was just worried how to get them out and the idea of going out the cargo door is great.
    I also have no solar on board and no  inverter, just a solar charging port on the driver side and a shunt next to the distribution box. I was wondering about the need to remove the passenger third of the bed platform. Did you remove the hinges to do that?
    And did your require more cables for your new battery?
    Thanks
    My cover looks like this:
    I learned that when nuCamp did a major Alde repair the technician did not secure the bed panels well. I removed all of the screws, realigned the panels and refastened them while I was doing the battery install. I did add new cables for the new charger and was able to reuse all of the original cables.  Don't have the ability to make a cable so I bought premade cables that were sometimes oversize or longer than necessary.
    2019 T@B400
    Southern California
