2 nights ago, I turned on the heat using electric shore power connection at campsite and it worked ok. Last night it didn't work so I used gas which did work? The little circle in the Alde screen showed it was supposed to be working but I obviously didn't hear it like did when I switched to gas. The temperature was about the same both nights. Must the lightning bolt option showing either 1kw or 2kw be on? I thought that was just for hot water and not cabin heat, and I don't think I had that on when it did work.
(Edited for search purposes. Moderator)
0 ·
2017 F-150
Coeur d'Alene, Idaho
