If you plug your TAB into a GFCI breaker, does your Multiplus II trip it when it turns on?
I've just installed a MultiPlus-II
12/3000/120-50 inverter/charger in my TAB400, and it is tripping any GFCI outlet I plug it into at the moment when it starts charging the battery. Seller is saying "they all do that" and don't use a GFCI outlet. I would like to know what the community experience is.
A GFCI trips when it detects a difference in load (current) between the hot and neutral. I've found wiring issues on either the neutral or ground side can trip a GFCI. Have you checked to make sure all your "new" neutral and ground connections for this install are properly connected/terminated?
What do you have your Multiplus chassis grounded to?
https://community.victronenergy.com/questions/161020/multiplus-ii-2x120v-tripping-gfci.html
Ken / 2023 Tab 400 “La Bolita” (20,000+ miles) / 2024 Toyota Sequoia
2024 - 1 Trip - 20 nights - 3 National Parks, 2 National Forests
@rh5555, I believe the overall premise of the above Victron Multiplus II 3000 GFCI thread focused primarily on the difference between the Euro and US GFCI hot/neutral leakage current thresholds. When a given threshold is exceeded, the GFCI cuts-off all power to the circuit. The Euro threshold is ~30ma. The US is ~6ma, which is much more stringent (and safer). If Victron is selling Multiplus II 3000's (in the US) based on the Euro threshold then that would explain why so many folks are experiencing issues with US GFCI's.
I believe in your previous post you connected your Victron Multiplus II 3000 directly to a GFCI protected outlet (bypassing everything in your 400) and it tripped the GFCI. If true, then it would appear your Multiplus has >6ma of leakage current. I suppose there is the possibility the wire or plug you used caused the leakage, but more than likely it's the Multiplus.
Did you ever find a solution to this ? I am having the same problem with my brand new multiplus 3000/12 120V unit.
Trailer - 2018 Tab 400 with Solar
TV - 2014 Toyota Tacoma Double Cab with bed rack/truck tent
Adds - Jackit bike rack with tongue rectangular tool box
