Short in wiring?
StefanieG
Member Posts: 3
I just purchased a 24 NuCamp Tag classic. The lithium battery is fully charged, yet it doesn't always work. There are times that the overhead light inside the camper flickers. Twice I've gone back to check power and nothing will come on. When checked again everything works. Seems this is a possible short? Needing advice.
Everything works fine when connected to shore power.
What are you using to tell you the battery is "fully charged?" The Victron app?Have you checked over the connections at the battery to make sure things are nice and tight?
The connections are tight and I used a voltage meter to che0
Hi @StephanieG - just to make sure you know there is another forum specific to TaGs.
https://teardrop-trailers.vanillacommunity.com/
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Thank you.1
