2017 Tab 320S-- the little toggle that screws open the fan vent feels like the screw is stripped or something? I have to take off the screen cover & use a stick or something to push open the vent cover-- it will stay open & will screw closed but will not lift the vent cover. I have tightened the screw several times but doesn't fix the issue -- ideas?
2018 Tab 400
0 ·
"Just Enough"
Here is an Amazon reference Knob with Screw
Worse case the metal lifting arm/crank could be damaged.
A good inspection should clarify if you need a Knob or Crank & Knob
Here is an Amazon reference Lift Arm/Crank {you should verify correct for your fan}
St Catharines, ON
St Catharines, ON
If the knob rotates on the shaft, but doesn't raise the vent, then the replacement knob is the right part for you.
eTrailer lists the Lift Arm assembly as:
Replacement Lift Arm for Dometic FanTastic Roof Vents
"Just Enough"
