Hi everyone,
Background:I have a 2024 TAB 400 that came with a 100Ah Battleborn lithium battery and 310W solar panel.
Dry camping this past weekend, our battery capacity would drop to around 60Ah right before dawn from using lights, running the fridge, running the sound system for an hour or two, keeping the Alde on all evening and night, and running a white noise machine at night.
Our campsite had plenty of sun exposure so we were back at 100Ah by around noon.
I would like to be less reliant on solar for cloudy, winter days in a heavily forested campground so I want to double our battery capacity, which should be enough for 2-3 night camping trips without worry.
I considered getting another identical 100Ah Battleborn and wire it in parallel, but it would set me back about $1000 so the biggest downside is cost here, but can't beat the simplicity and ease-of-use.
I also considered an EcoFlow River 2 Pro power station, which has 64Ah of capacity and is currently on sale at Costco for $400. However, this is really only maybe 50Ah of usable capacity once you consider the inefficiencies of going through an inverter and a converter to power all the 12V stuff. Also, I don't like the idea of leaving it outside where the short power connector is, or just lugging it around in general, and wasn't sure how well it would be able to charge the Battleborn directly over DC if I wanted to address the inverter-converter inefficiencies (I might have needed a separate DC-to-DC charger, which probably has its own losses?)
Then I found a post by
@CrabTab on this thread:
https://tab-rv.vanillacommunity.com/discussion/14199/solar-generator/p1 where they suggest just getting a 2nd, possibly cheaper battery and using a battery isolation switch to activate it. I really liked this idea as it's quite economical and possibly provides the highest Ah per dollar, without being too inconvenient
So I ordered a LiTime 100Ah battery for $252 and a battery isolation switch for $40.
https://www.amazon.com/dp/B084DB36KW (there was a lightning sale yesterday)
https://www.amazon.com/dp/B000K2MCR2Actual question:
Here's a picture of the battery bay. I plan to put the new LiTime battery directly below the existing Battleborn. I've added little numbers to all of the positive writes coming out of the positive terminal.
When adding the battery isolation switch, which of these wires do I need to move over to the switch so that they can be energized by either battery, and which of them should be left on the Battleborn battery?My current understanding is:
1. This is the main wire powering the trailer and charging the battery, so this needs to be moved to the battery isolation switch.
2. This is the power for the Victron shunt. It doesn't matter where this one goes since the power draw is so minimal I could just leave it on the Battleborn even when it's disconnected from the battery isolation switch.
3. No idea what this wire is. It has a fuse. Does anyone know?
4. No idea what this one is either. I bet I could figure it out if I took off the panel on the left, just haven't had a chance yet...
5. Battery heater. This should stay on the Battleborn. There's no heater on the LiTime so there's no point in moving this one over.
Thanks!
Bus bars would make this so much cleaner.
I think you are adding too much complexity to your system and points of failure. Plus, you will be making it more difficult for monitoring the batteries and charging via solar.
Thanks @kevmon, so it must be that #1 goes to the inverter (makes sense given its size), #3 powers the 12V stuff in the trailer (makes sense given the fuse), #4 goes to the solar charger.
Hmm I was thinking that if I connected the shunt to both batteries and configured it via the Victron app that it's a 200 Ah battery, what I would see is that when the Batttleborn is 90% depleted the app would show me I have 110 Ah left. So I would flip the switch to activate the LiTime battery at that point.
Then when the app shows 20 Ah left, that would be the point when the LiTime battery is also 90% depleted.
Same goes for charging the batteries back up again -- when the app shows 110 Ah or 0A being pumped into it means one of the batteries is full and it's time to flip the switch.
Hmm I hadn't thought of this -- I figured that since they're both LiFEPO4 that they would have the same charging profile, but let me look into this further...
Acknowledged, I have 4 AWG cables and I should only need about a 12" length.
@elbolillo heh as I was typing the above I was definitely thinking "man elbolillo is totally right, this is pretty complex". But the Battleborn battery is just so much better built than any other battery that I can't bring myself to sell it. It's irrational, I know -- if I had a trailer with no battery and $1000 in cash, I definitely would not drop it on a Battleborn. But now that I already have one, I don't want to sell it
Some things I learned / noticed:
1. Victron recommends connecting the battery before enabling solar charging. If I switch from Battery 1 to Battery 2, it momentarily goes through the "off" position which may not be great. I need to remember to turn off the solar charging through the Victron app before turning the switch.
2. The solar charge controller came from the factory with a float voltage programmed to 13.8V which I think is too high. Both Battleborn and LiTime recommend float voltages of 13.6V.
3. I'm still not sure what wires #3 and #4 are. It seemed to me while I was testing the various wires that both the 12V power in the trailer and the solar charging are supplied through wire #1.
Is there ever a reason one might want to run them in parallel for an extended period, given they're from two different manufacturers?
Should be fine even if they're from different manufacturers, but some people suggest you might decrease their service life slightly from extra charge/discharge cycles as they try to match each other's voltage.
That does mean that it's probably not a good idea to flip the switch to 1+2 in the middle of a trip when the two batteries are likely at different voltages.
Mismatched batteries is a problem. Worse, having batteries at different charge states is a real problem as there can be a huge amount of current created if a charged battery and a discharged battery are connected together. Batteries of the same manufacture/model should have been used and both should be fully charged individually and then connected in parallel and allowed to balance. Having two batteries in different charge states on a switch that will allow them to even momentarily be connected together in parallel means your depending on the batteries BMS to limit the current between them or shut them down. Dumping a lot of current from one battery to the other can create a lot of heat and lead to disaster.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Might be as high as 2V / 10 mOhm = 200A?
