RMo
Member Posts: 162
I’ve been a fan of 3-way fridges and their ability to run “forever,” and we’ve managed ok in the heat by keeping the driver’s side fridge vents in the shade when parked or camping. On our current trip, however, we had major failure: driving west through Tennessee and Arkansas with temps in the high 80s and the sun beating down, the internal fridge temp rose to 50. Now we are using the fridge for vegetables and a cooler for more perishable items. Not ideal, so we’re considering the value and benefits of a 2-way fridge.
My question goes out to those who’ve been in extreme conditions with their 2-way fridges, particularly those with a driver’s side fridge in their 400. Being as specific as possible with info on temperature, sun position and other variables you’ve found to be relevant, when has your fridge reached its “breaking point” and not been able to maintain a 41 degree temp? Thanks in advance for any info.
2020 Tacoma TRD Off-Road
We spoke with a couple in an Alto Safari who were driving in the same conditions as us and they said they had no issues with their 2-way?!
2017 Highlander Limited
From my limited experience, a 3 way would run just as much due to its less efficient nature, but will not have the current draw.
Hope this helps.
2020 F150 2.7l V6 Turbo
Tucson, Arizona
https://www.yeti.com/shop-by-color/seasonal-color-collection/10022420000.html?utm_source=google&utm_medium=cpc&utm_content=__iv_p_1_g__c__w__n_x_d_m_v__l__t__r__x_pla_y_7597392_f_online_o_10022420000_z_ZZ_i_en_j__s__e__h_9028782_ii__vi__&gad_source=1&gbraid=0AAAAADI2_49oRBIImMjjkiLz5jvwl43t7&gclid=EAIaIQobChMIk8mFn_2chwMVox-tBh228ggJEAQYAiABEgICjfD_BwE&gclsrc=aw.ds
The pull out shelf comes complete. You actually specify the width after ordering. Here’s the link.
https://www.homedepot.com/pep/Slide-A-Shelf-Made-To-Fit-Slide-Out-Shelf-6-in-to-36-in-Wide-Full-Extension-with-Soft-Close-Choice-of-Wood-Front-SAS-SSO-MTF-S/300941158?cm_mmc=ecc-_-THD_ORDER_CONFIRMATION_BOSS_STH-_-V1_M1_CA-_-Product_URL&ecc_ord=W890783984&em_id=256809d48cafa5be2cead92b8dedee73451476a60c7dde3c81dc5c98d7c17b78
BTW, if you haven’t removed your fridge yet, I discovered I had to remove the top of the bumper in order to get it out. Just needed to take out a few screws.
The thermometer was attached with magnets to the "freezer" compartment, so I'm not sure how reliable it was. We're still trying to verify it.
To mitigate issues with unpredictable temp, we brought BougeRV car fridge. It seems to be more reliable with keeping the temp than the one installed in our T@B
