Little Giant Steps for your Tab 320
EasternJL
Member Posts: 108
I posted some questions a few months ago about what folks were using for steps into their 320s--- as an alternative to the single step on the camper. Others may use these already, but I thought I'd share what I ended up with. Aside from being just a touch narrow (compared to the built-in step), the Little Giant Safety Step step ladder is a perfect fit for giving you two steps up to your 320 (not sure about the 400). And, as opposed to having a uni-tasker for steps, these also work great for stepping up on your truck-- or to reach things higher up on your camper. There's a back rail that flips up for leaning when you need it-- and it folds down nicely when used as steps. I thought I might have to remove that rail for it to fit close enough (because of the 320's step), but it works great as is. They are a little pricey, but worth it.
Nice! When we got our tab in 2019, we bought a medical step but it is a single step and it’s still working fine but this looks very nice and stable. Do you have a Boondock or original? I will need to check the height because we are Boondock.2019 Custom T@B 320 U Boondock Lite-ish
We've slept in 34 states, 2 countries & counting -
This is what we have.21 bucks. it folds up into the net on our door2019 Custom T@B 320 U Boondock Lite-ish
Hey @ColleenD2--- we have a boondock model and the step heights are just right. Not sure how it would match up for the non-boondock folks.
My knees definitely prefer two steps instead of one! We added a little step in front of the stock step originally, but it was still somewhat of a big gap up to the camper (from the stock step up to the threshold). And as I mentioned above, having a little step ladder available is handy for other purposes as well. -
That's really nice! The step on my T@B lost a screw on my last long trip and I bought an inexpensive, folding plastic step at Costco. If the ground is uneven, the little folding support collapses.
This looks way nicer than just fixing my step for stability and getting up and down with my hands full. Thank you for sharing! 2019 T@B 320 S | 2019 Subaru Ascent -
Ordered! Thanks so much for this.2019 Custom T@B 320 U Boondock Lite-ish
I suppose you could remove the factory installed step and bracket to have close to zero weight penalty for the Little Giant.2019 Tab 320 CSS, 2019 Ranger TV, OH
@Slackers That's true, though I do like the option to use the factory step if I'm using the Lil Giant elsewhere (or at home, etc.). I keep the LG steps in my truck for travel, so I don't have to worry too much about the weight (and my total weight is usually well under).
- 917 Introductions
- 73 Teardrop Groups & Links
