Just planning ahead here for a possible boondock(ish, the campground won't have 30/50amp hookups) camping trip. We want to ensure we don't run into problems and just want to clarify / verify / find out a few things. Our camper is a 2022 T@B 400 Boondock, stock batteries and solar (so lead / acid I believe and one solar panel)
- Would we be correct in presuming we can leave the water pump on, and it will only draw power when it brings the pressure back up in the lines, such as from flushing the toilet? Or should it be turned off when not using water? (leave aside the possibility of a blown line / fitting)
- Are we correct in presuming that the inverter DOES have a constant draw when on, and thus, to leave it off except when we need a working outlet?
- The lights are not a significant draw on the batteries
And the batteries getting recharged / how quickly they charge depends entirely on how much sun the solar panel gets.
Upgrading the batteries and adding backpack solar is currently not in out plans / budget.
Yes, the inverter draws power just by being on.
The different lights in my 2020 T@B 400 draw significantly different amounts of power, as evidenced by monitoring via a smart shunt. In my trailer, the light strips draw the most power.
2020 Tacoma TRD Off-Road
Then minimize opening the fridge as much as possible. That despite the fridge would be running on propane. Probably also keep a couple of the ice packs in the freezer to cool them down to swap out the ones in the cooler.
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
So, comparatively speaking, this might not be that big of a change for us.
Jay and Kat
What I didn’t consider is how much solar it takes to get back to 100%. With the stock 160w panel it struggles to recharge. If we do longer boondocking trips we’ll definitely look at getting a solar suitcase to supplement.
