Breakaway Brakes and Battery Disconnect Switch (T@B 320)
2»
  • mjwaldnermjwaldner Member Posts: 55
    I was referring to where is the fuse for the emergency break. Sorry I was not clear.
    2021 T@B 400 BD
    2025 Toyota Tundra / Nashville, TN
  • MuttonChopsMuttonChops Member Posts: 1,905
    @mjwaldner ;
    No difference still no fuse.
    Emergency Brake Switch applies full Battery Voltage to brakes; if the battery cut-off switch is On & the switch/pin is pulled.
    Typical nüCamp wiring:
    On my 2021 the 10 gauge wire that runs to the front junction box is tapped directly onto the incoming battery + lug on the DC fuse panel. Not on the 30a fuse as yours is. I guess the 40 amp main GLOSO breaker that feeds the DC Panel is protecting that cable.
    2021 T@B 400 BD
    picture was to show Brake Wiring
    that fuse panel is a 320S configuration, sorry should have blocked out
