Best package of replacement fuses?
Hello and thanks,
Have purchased a set of replacement fuses? I just bought a Tab 320. I would like your recommendation on a packaged set of fuses recommended for my tool box. Your thoughts?  I understand the flat fuses. But, I also have a couple of tiny glass tube fuses.
Dan
  • You are probably not going to find a single package with every fuse you need. You might be able to get an assortment of the plastic blade fuses, but I suspect you will need to source the several glass fuses individually. (Someone please correct me if I'm wrong!)
    You might find this resource useful. It's based on a 2016 320. Newer models might have some differences, but this should give you an idea what and where to check for various fuses that may not be immediately obvious.
  • I just bought a 2023 tab 400. I have the same question. Has anyone found a replacement fuse kit that covers most of what I’ll need in my tab?
  • This is what I bought, it has all of the std fuses, with the exception of specialty ones, which you can buy separately. https://www.amazon.com/dp/B06XY2V532?psc=1&ref=ppx_yo2ov_dt_b_product_details
  • this should suffice.  https://www.amazon.com/gp/product/B01MQGL5I1
    it has a lot of fuses.  every size.  nicely organized, and dirt cheap.
