Paint laminate cabinets?
Has anyone attempted to paint the laminate cabinets on a 2018-2019 Tab 400?
2018 Tab 400
  • Citruscountytab400Citruscountytab400 Member Posts: 20
    Use a good etching primer and sand before you paint.  Nothing different than doing this in a house.  I will be repainting the painted white cabinet doors under the sink. the very cheap materials/paint used stains and can't be cleaned.
    Full-time rving since 2006, tab owner since 2022
    So sand with like a 180 grit then etching primer then paint?  Would you use a sealer also?  The color on the upper cabinets is just so ugly, IMHO.
    2018 Tab 400
