Stud sizes in 7 pin connector junction box?
Hello, I've been trying to find this information everywhere and keep coming up empty.
I bought an Autowbrake brake controller and I want to start getting it ready this winter by installing ring crimp connectors on the end of the wires.
The only information I'm missing is, what are the sizes of the studs in the 7 pin connector junction box? Does anyone know? Looks like 1/4" to me and I'm assuming that's pretty standard.
See picture below to see what I'm looking for. Thanks!
2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
The nut is sized at SAE #10/32 threads. Hope this helps.
Kay and Tom - SW Wisconsin - Silver T@bernacle - 2018 T@B 320S Boondock Silver/Black trim TV, 2018 Chevy Colorado, Silver/Black trim, Duramax, TowHaul, IntelliHaul0 -
Thanks but what doesn't it mean in terms of ring connector size? 1/4"? 3/8"?tybladesmith said:The nut is sized at SAE #10/32 threads. Hope this helps.2022 T@B 320S Boondock
Instagram: new.t@bventure1 -
Below a 1/4" nut sizes switch to numbers, starting at #12 and going down from there for smaller sizes. So the stud size is #10 with 32 threads per inch. You'll find them in hardware stores.
https://www.boltdepot.com/fastener-information/printable-tools/US-Nut-Size-Chart.pdf
Rich2019 T@b 400
Thanks @Horigan. I'm not looking for a nut size. I'm looking for the size of crimp on ring connector I should be ordering. Sorry if I wasn't clear. I think 1/4" will do.
Instagram: new.t@bventure0 -
First, you need to know the wire SAE size for the cable you are going to terminate (Autobrake cable wires), which is typically 8 or 10, or a combo of the two, then you need to get a crimp on ring connector that fits a No 10 stud, typically these connectors will have a blue or yellow insulator on them )see your photo). Here is a chart showing the choices for a no 10 stud:
https://www.mcmaster.com/crimp-lugs/insulated-ring-terminals/for-screw-size~no-10/
A one quarter inch ring would be too big.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.2 -
Kay and Tom - SW Wisconsin - Silver T@bernacle - 2018 T@B 320S Boondock Silver/Black trim TV, 2018 Chevy Colorado, Silver/Black trim, Duramax, TowHaul, IntelliHaul1
I'm about to get an Autowbrake unit for my 400. I'm curious - how did you deal with replacing the cord (with its 7-pin female connector) with the bare wires of the Autowbrake? There needs to be some way to weatherproof the passage into the junction box.2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno0 -
The wire from the Autowbrake get connected directly into the junction box mounted on the frame. A waterproof grommet can be used for the hole where the wire from the Autowbrake enters.geoB said:I'm about to get an Autowbrake unit for my 400. I'm curious - how did you deal with replacing the cord (with its 7-pin female connector) with the bare wires of the Autowbrake? There needs to be some way to weatherproof the passage into the junction box._____________________________________________________
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
