Just no air conditioning solution the isn't noisy
I squandered another few hours reading all about Generator soundproofing and running the A/C in the T@B 400, there is just no good fix. At a place like AMA Vintage Days at Mid-Ohio the noise will be a non-issue in a huge non-stop 2 and 4 stroke moto-woodstock, just run the genny. (the WEN 2350w I picked up does run the cool cat)
I tested it today and got the trailer pretty cool, but it heats up again pretty quick after shut down.
Watched a bunch of vids on soundproofing that showed limited results at best.
It will be nice to have the genny for power outages at home and such, but I cant see running it much when camping unless I used it to power the lithium 10amp charger clamped to the battery, but jeez if we are that low on DC volts it would still take a long long time to raise the SOC.
Confirms what I kinda knew, keep up as long as you can with solar suitcase and enjoy the heat. Or camp with hookups.
  • MuttonChopsMuttonChops Member Posts: 1,877
    Aubrey said:
    . . . . Or camp with hookups.
    Yep, running a generator is a major love - hate situation.
    In the hot months I seek out electrical hook-up sites.
    The few times I've used a generator were at boondocking sites so no neighbors to disturb.
  • manyman297manyman297 Member Posts: 1,422
    I only try to use the generator at boondock sites where we’re spread out. I know the more powerful inverter generators won’t be as loud as the smaller ones (I have a Westinghouse 2400) under load.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    I've slept in a tent for a Mid-Ohio Indycar weekend or two-many years prior to owning a Tab. Yes, late to bed, early to rise whether you wanted to or not.
    On a just completed cross country trip with only one night of shore-power, a small well-aimed USB fan made a difference.
    Yep, definitely noisy.  We have the quietest rated one on the market.  But it is a necessity for us Florida travelers, except in winter.
    Odessa, Fl.
  • MickerlyMickerly Member Posts: 479
    The outside ceiling is aluminum which absorbs heat from sunlight. The frame is also aluminum to help conduct heat to the interior. Add a solar panel, which heats up while operating.
    To keep the trailer cool, you have to park in the shade.
    Wait a few months, It works in reverse in the winter... ; )
    2018 320CS-S
    "Just Enough"
