Zerk fittings
VaagVaag Member Posts: 2
I have a 2007 T@B. I thought I had maintenance-free fitting but it is possible that I need to perform maintenance on the fittings. Any advice is appreciated!
  • T@BuhuraT@Buhura Member Posts: 97
    Hi Vaag, the Dutchman T@Bs use the ALKO chassis and axle which use sealed/automotive bearings. They are maintenance free.
    2006 Dutchman T@B T16, 2010 Volvo XC90 3.2 R-Design
    There ARE Zerk grease points for the surge brake mechanism. Very easy to use a grease gun once a year. They are located under the tongue. Just shoot some automotive grease into the two fittings using a grease gun with the correct Zerk fitting.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
    While the ALKO bearings are maintenance free and do not have to be greased, they do wear out over time.  I think LG still carries them.  Any mechanic should be able to replace them.
    Sterling, VA
