Extra Long Lagun Table
Bought some scrap maple and walnut pieces from a local cabinet maker and made a new top for my Lagun table.
It's actually 36" long (8" longer than the original).
I'm hoping the extra length and weight on the bracket don't present any problems.  Please let me know if anyone has any input.  I can always cut it down if I have to.  If necessary, I can cut the extra length off and attach it as a drop leaf.  I'm hoping the extra length will be handy as extra prep surface for cooking.
  • AndreO
    AndreO Member Posts: 88
    Nice craftmenship Basil48192. I have a 2018 with the older table and could be wrong but always felt the new Laguna table was way too small.
    AndreO
    Ontario, Canada
    2018 Tab 400
    Ford F150 2.7 Lariat
  • Basil48192
    Basil48192 Member Posts: 444
    Thanks! @AndreO.  I was pretty happy with how it turned out (bought a new planer so needed a project to try it out).  At 36" long it just misses the corner of the bathroom wall and will just turn 90 degrees and touch the side cushions.  I think I'm going to like the extra surface area.
  • Mickerly
    Mickerly Member Posts: 517
    I did 34in by 24in. Having a CS, we use the table mostly outside. The mount is off center allowing the table to reach to the kitchen for additional prep space.
     Looks very nice.
    2018 320CS-S
    "Just Enough"
  • Freespirit
    Freespirit Member Posts: 187
    @Basil48192, this is from the Lagun USA website:
    TMP= Table Mounting Plate
    What size tabletop is recommended for Lagun?
    • Tabletops are NOT INCLUDED with systems.
    • System with Standard TMP can support up to 50 lbs & a tabletop up to 30″ x 40″.
        • This includes the weight of the tabletop plus anything placed on it.
    • System with Folding TMP can support up to 40 lbs. & a tabletop up to 24″ x 36″.
    2020 TAB 320 U
    TV 2025 Telluride X Type
  • Basil48192
    Thanks everyone for the input!  My table top weighs about 22 lbs., so as long as we keep our meals reasonable, we should be fine!
    Thanks again.
  • AnOldUR
    AnOldUR Member Posts: 1,762
    And no elbows on the table.  =)
  • Basil48192
