Thermistor position for Norcold N4104
Does anyone know the stock position for the thermistor in the Norcold N4104 3 way refrigerator? I've moved it so many times trying to get the fridge to work properly, I have forgotten the baseline setting. Thanks in advance, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
2008 Toyota Tacoma
There are some YouTube videos on this, but it is always hard to sort out. The Thermistor apparently has to be on the "correct" fin in the fridge. This is one. There is a Mark Turney video that shows how to replace the entire gas valve/thermostat/thermistor assembly.Here is the Mark Turney video. I replaced mine in my 2017 and it really helped.
https://www.youtube.com/watch?v=Vl0X8-5z5Qk&t=5s
Thanks for that info. It seems every model has a different position for the thermistor. I have an inquiry into Norcold about the N4104, hopefully they will sort it out and get back to me.2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland0 -
So Paul Unmack from Fridge Defender told me it was the 5th fin from the right. Norcold support never got back to me. Great customer support.2021 T@B400 Boondock
2008 Toyota Tacoma
Was there a discussion about how high or low on the fin it should be? Glad you found a good answer to start.
Towed by 2014 Touareg TDi0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
https://www.youtube.com/watch?v=XYZvzGPa26c
