Thermistor position for Norcold N4104
Does anyone know the stock position for the thermistor in the Norcold N4104 3 way refrigerator? I've moved it so many times trying to get the fridge to work properly, I have forgotten the baseline setting. Thanks in advance, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
    pthomas745 Administrator, Moderator Posts: 4,685
    There are some YouTube videos on this, but it is always hard to sort out.  The Thermistor apparently has to be on the "correct" fin in the fridge.  This is one.  There is a Mark Turney video that shows how to replace the entire gas valve/thermostat/thermistor assembly.
    Here is the Mark Turney video.  I replaced mine in my 2017 and it really helped. https://www.youtube.com/watch?v=Vl0X8-5z5Qk&t=5s
  • madtrout
    madtrout Member Posts: 63
    Thanks for that info. It seems every model has a different position for the thermistor. I have an inquiry into Norcold about the N4104, hopefully they will sort it out and get back to me.
    2008 Toyota Tacoma
  • madtrout
    So Paul Unmack from Fridge Defender told me it was the 5th fin from the right. Norcold  support never got back to me. Great customer support.
    2008 Toyota Tacoma
    Was there a discussion about how high or low on the fin it should be?  Glad you found a good answer to start.
