Twisted Strings on Front (Kitchen) Shade/Screen
Front window shade/screen on my 2018 T@AB 320S is sticking and hard to move. Looked inside the channels and noticed unlike my side windows, the white and black strings are crossed. How do I uncross them? Was going to take off the window but only see screws at the top of shade/screen not the bottom. Can you take out the adjusters at the ends and uncross them that way somehow.
Trips - 48  Mileage - 63,452
  • mlk51mlk51 Member Posts: 12
    The bottom screws are hidden in the pleats on the bottom of the shade.
    Mary Lou, Grand Rapids MI / 2017 T@B 320-S / 2015 Chevy Equinox w/ trailer package
  • rcarlson1957rcarlson1957 Member Posts: 262
    mlk51 Finally figured it out, took it out and fixed everything. Thanks!
  • DenverJaguarDenverJaguar Member Posts: 76
    I wish I knew how to uncross the strings. I just took the assembly apart and couldn't manage to get the strings moved, and it was a nightmare to put back together. I'm just going to buy a new assembly, but there's not one listed on the Nucamp site; they only have the screens for the side windows.
  • TourDeForthTourDeForth Member Posts: 127
    edited August 2025
    I think the only way the strings can be twisted is if one of the strings slipped out of its catch and would need to be re-strung. It would be strung the same way as the side window. Remove the entire shade assembly and then take a look at the side ones from the outside, you should be able to see the strings and the paths they are strung on.
    Here are few videos I referenced when I went to adjust the sag in my shades and screen. I learned a lot from them and was able adjust my shades even though they were slightly different, I got the job done:
    https://youtu.be/n3p8vyrRBx0
    https://youtu.be/gzaoCbByOmE
    https://youtu.be/wTcUsNeEVDk
    John, Northern California
