New fridge door panel?
Hello all-  previous owner had scratched up the door panel on the 2-way fridge in my Tab 400-  has anyone replaced just the door panel & if so how to remove old panel & replace & where did you get the new panel -- OR what have you used to cover the door panel??
I tried to do a search but apparently not using a correct search term
Thank you
2018 Tab 400
  • XenanMeXenanMe Member Posts: 81
    You could just put some peel and stick wallpaper over the front panel.  Might be simpler and less expensive.
  • lkc001lkc001 Member Posts: 879
    thank you for responding!  After researching how to remove the panel on this specific fridge which requires removal of the door to access the screws on the BOTTOM of the door (instead of just having to remove trim from the SIDE of the door like many other RV fridges, which is really easy—duh)——I decided your option is  going to be the easiest.
    2018 Tab 400
