External antenna fell out of mount (2019 T@B400)
jimcenname
Member Posts: 348
While washing my 2019 T@B400 the external Jensen antenna fell into my hands. Something is broken. The cylinder you see in the photo should be attached inside, then the antenna base screws into it. I don't see anything in the part still on the side of my T@B that will hold it. Since I don't use the Jensen I would mind removing the antenna base from the outside but it's not obvious to me how to do that. Have you either had this happen or have you removed your antenna?
2019 T@B400
Southern California
Full-timer since 2019
Southern California
Interesting. Looks like the bonding that held the sleeve in place has failed. Removing the base (since you never use it) will of course leave a sidewall hole to fill/cover/seal.
My 320S uses the same antenna.
For the black-tank version 320S the antenna can be reached from the wet-bath hatch behind the toilet. No Idea on access in TAB 400.
The Antenna Mount (inside) looks like this:
Adventures: 59 Nights: 411 Towing Miles 50,3501
- 418 Service/Maintenance & Recall Notices
