I looked at the bonnet style awnings that slide into the Keder rail and decided that just wasn’t for me. I prefer a simple traditional style awning. So I purchased this awning from KickAss Products USA.
https://kickassproducts.com/products/kickass-2-0m-x-2-5m-heavy-duty-awning-with-led-light-strip It’s 6.5 x 8 feet and uses built in poles with a couple tent stakes. I like the way it looks and the ease of setting up. It has a LED light strip that plugs into USB as a bonus. It was tricky to install on the Keder rail but came out real well.
2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4
John, Northern California
4 ·
Could you provide a few details and/or photos of how you attached it. TY
Southern Maryland
I attached it to the Keder rail and also used double sided tape. It’s on there pretty solid.
First, I took the awning completely apart, which was very easy, a couple bolts and two screws. (But I left the black weather cover on due to rivets.) Once I decided where I was going to mount it (high enough to let the LED strip hang down without touching the porch light.) I put two layers of double sided tape on the awning bracket between the Keder rails. I used a level and stuck it on. There is a little less than a 1/4 inch gap between the awning bracket and the wall which is why I used a double layer of tape. The tape is strong and the awning bracket is light aluminum.
Second, (the tricky part) I eyeballed where to drill four holes to reach the Keder rail slots (two on each side.) Then I slid two Keder rail stoppers on each side, up under the awning, using a plastic rod to slide them in place and screw the bolts in. I applied blue loctite (but still plan to check them periodically.) I reassembled the awning. I also ran a bead of silicon clear caulking across the top of the awning bracket and trailer wall to keep water from pooling on the double sided tape and running down the wall of the trailer.
The parts I used were from Amazon and Lowes. I ordered these Keder rail stoppers from Amazon https://www.amazon.com/dp/B0D3WRRCN1?ref=ppx_yo2ov_dt_b_fed_asin_title and some double sided tape from Lowes Scotch-Mount Extreme Double-Sided Mounting Tapes 1-in x 5-ft Double-Sided Tape
Would I do it again? Absolutely, but a lesson learned: eyeballing where to drill the holes was a dumb idea on my part. I missed by an 1/8 of inch on two of the holes so there is a bit of scarring hidden under there, doh! I would have been better off making a template out of wood or plastic in the shape of the awning bracket and then mounting that first to draw the kedar rail slot on to it so I could precisely drill the holes. Oh well, next time!
Southern Maryland
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Just curious….were there other brands you looked at or considered that might attach to the keder rail? Or was the removable bracket the attraction on this brand? This concept intrigues me.
Southern Maryland
2015 Little Guy T@b, TV - 15 Toyota Highlander
"Good friends beware! the only life we knows Flies from us like an arrow from the bow, the Caravan of life is moving by, Quick! to your places in the passing show.”
I should have added that my trailer is older and the Keder rail is nearly 3/4 of an inch.
If I had been faced with a 3/4 inch gap like you describe then instead of stacking the tape I would have used a 1/2 inch piece of wood or other material and used that as a spacer with double sided tape on each side of the spacer.
My Kedar Rail style awning was made from a sunbrella type fabric at a local shop. The key part for ease of set up is the bead material on the awning. I found a kevlar bead that slides into the rail from one end by one person. I usually use 4 poles which means the guy lines can get a bit busy. It has been in use for 5 summers now and I am really happy with it. Stores in a big kayak dry bag. Set up time is solo, maybe 10 minutes. (including beer)
For more coverage I have added an additional 6.5x6.5 foot black mesh fly that has a keder rail bead. The KickAss awning has a keder rail on the end of the awning that I can add the fly to and stake out at an angle to extend the shade coverage and adds privacy by blocking direct sunlight into my trailer as the sun moves. I've bought a 6.5 foot keder rail for attaching to the left or right side of my awning with velcro straps to move the fly around to provide shade depending on how I've parked the trailer. Sometimes I don't have a choice for the orientation to the sun.
