Thanks
qhumberd
Moderator
Ultimate Toys Teardrop Owners
Brian56
Brian56 Member Posts: 23
I wanted to start a discussion for owners of the Ultimate Toy teardrop to introduce ourselves and share. Please also share your thoughts on stuff like mods, mantenance, camping excursions, or anything else related to this unique nuCamp product. Non-owners are also welcome to participate!
Jeep Grand Cherokee
Dallas, TX Area
  • Brian56
    I dropped my camper off at the dealer Sat to take care of a few minor items we've discovered during our first few trips. Nothing really major. The biggest being water leaking into the clamshell from rain. The caulkling has some obvious issues at the top, but wanted to see if there are others causing this.
    Jeep Grand Cherokee
    Dallas, TX Area
  • jbajor
    jbajor Member Posts: 233
    We love ours!  I am 6’2” and can’t imagine a narrower cabin for sleeping.  Love the propane furnace for cold mornings.   Full bar and espresso machine in back too! Enjoy!
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • jbajor
    Here is the full set up with Bar and Espresso Machine....
    Volvo XC-40
  • jbajor
    I heard from UT that they have stopped selling the camper!!  Really sorry to hear it.  GREAT product!
    Volvo XC-40
  • Brian56
    Just back from camping last week, and I agree we love our UT. Apparently they only made 100 UTs, so that should be good for our value.
    Jeep Grand Cherokee
    Dallas, TX Area
  • Brian56
    Also, the new Tab 360 is pretty much the same as the UT in size. Apparently yhey are going to make a clamshell version of the 360 next year.
    Jeep Grand Cherokee
    Dallas, TX Area
  • rfuss928
    rfuss928 Member Posts: 1,180
    edited September 2024
    IMO - The UT is the best version of the 320 platform ever built.  The interior  kitchen has more counter space and storage than the 320S.  Then there is the outside kitchen of the 320CSS again with more counter and tons of storage. There is a full standard queen size bed with over 4 feet of side on the aisle to sit.  The cabinetry has a high grade laminate over birch plywood typical of the 400 series and every audio/visual feature ever offered in a T@B.
    As a T@B CS owner for 14 years, for us, this was the ultimate upgrade of a very unique camper.  We're so glad we got ours...
  • jbajor
    Rfuss, I could not agree with you more!  Not only does its looks always turn heads but it is the perfect design! I am so glad we got one too!
    Volvo XC-40
  • nchayes
    nchayes Member Posts: 1
    edited March 2025
    Hello friends, excited to join the UT family as after multiple years of renting an RV for IMSA race weekends, finally pulled the trigger and landed (what looks to be?) one of the few remaining new UT's. Also towing with a XC-40 - relieved to see one of them in here as well.
    Working through the rabbit hole of the forums - I've noted some mentions of the lack of a UT manual, and as I bought this remotely, I didn't get a proper tour. Was curious if the 2022 320 CS-S was a close enough reference? Am noting the differences with the heating system and the Bosch Instant Water heater, etc.
    Thanks in advance.
  • Brian56
    This Facebook group for UT owners is also a good source of info. The fiels section has a lot of the manuals, etc. for the UT.
    Jeep Grand Cherokee
    Dallas, TX Area
  • Kbcabc
    Kbcabc Member Posts: 1
    Hey folks, We just purchased our UT woody and the dealer didn’t really have much knowledge about the systems on the camper.   I have a question about filling the flush tank on the camper  It didnt come with the attachment shown in the manufactures brochure to fill the tank.  Does it fill when you are filling the other water tanks
  • rfuss928
    edited March 2025
    Welcome to a very small club...
    There is no flush tank.  The toilet operates with the water system pressure.
  • jbajor
    Kbcabc, not sure what you mean by the 'flush tank.'  Only one tank of fresh water that serves, from and rear sinks (hot an cold) as well as the shower and the toilet.  Toilet needs the water pump on to operate went you push the flush button.  Cheers!  Jordan
    Volvo XC-40
  • jbajor
    Does anyone have a source and part number for replacement ‘baby moon’ hubcaps for my UT Woody?
    Volvo XC-40
  • rfuss928
    Been there - done that...
    https://www.amazon.com/dp/B075NM3NPD?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
  • jbajor
    Many Thanks!  These actually look like they are made better than the original!
    Volvo XC-40
  • jbajor
    Rfuss, I just received the hub caps….  They seem too tight to get on rim and do not cover rim up to the tire.  Valve stem also does not line up to fit in hole.  Did you modify yours to work?
    Volvo XC-40
  • rfuss928
    I just received and installed another of those hub caps.  West Virginia stole second one to go with the first I guess.
    The new one did seem very tight and had to be worked straight in. Not letting one side to seat before the opposite side is started wouldn't work.
    The valve stem never lined up very well on any of mine.  It seemed too short to be accessible so I added a short metal extension.
    I still have one original and am pretty sure they are the very same manufacturer.
  • jbajor
    thanks!  I will order some extensions...  I see that yours also do not cover the full rim
    Volvo XC-40
  • jbajor
    your valve stems look perfect!  How long an extension did you use?  19mm?
    Volvo XC-40
  • jbajor
    Volvo XC-40
  • rfuss928
    Valve stem extensions:
    https://www.amazon.com/dp/B08BVVJCFQ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
  • Brian56
    I removed the moon hubcaps when we got our camper and hav never used them. I did that because I couldn't use the wheel lock chocks with them. The only time I would use them is when towing and just decided that wasn't worth it. I may be over cautious, but I over secure my UT when in storage (wheel locks and tongue lock). When camping I always use one wheel lock and a tongue lock pin.
    Jeep Grand Cherokee
    Dallas, TX Area
  • jbajor
     Brian, are you interested in selling your old hubcaps?
    Volvo XC-40
  • Brian56
    Hi jbajor, sorry but I want to keep them in case I ever sell the camper.
    Jeep Grand Cherokee
    Dallas, TX Area
  • jbajor
    good call!  Happy Camping!  Cheers!  Jordan
    Volvo XC-40
  • Brian56
    You too. I think our camping is done until fall though. It's about to really heat up here in Texas. Will probably pick back up in Sept if it cools down then.
    Jeep Grand Cherokee
    Dallas, TX Area
  • jbajor
    WOW!  I am struggling!  Did you bend the clips slightly to loosen?  I have not yet resorted to a mallet as I am afraid that it will slip and break the valve stem...  CRAZY tight.  Valve stem extensions, however, are perfect.
    Volvo XC-40
  • jbajor
    Rfuss, how the heck were you able to get them on?
    Volvo XC-40
  • rfuss928
    jbajor
    They have to be worked straight in. Not letting one side get too far in before the opposite side is started won't work.  I sometimes use a small rubber mallet at the edge but it can dent the metal.  I usually use my fist.  Hold it nice and flat in the correct position and work the clips into the rim a little bit at a time ( 1/8 to 1/4 inch) tapping around the outer edge.
    If you bend the clips to make it easier to install it will also bounce off that much easier.  I actually bent the corners out a bit on a third of the clips to give them more bite on the rim.
