Where do the Alde lines heat?
I have a 2024 Tab 400
When I turn on the Alde heater it mostly just heats the bathroom and behind the seat in the dinette.
Where else should be getting heat? Where do the glycol lines go? Do we have a map of the system?
Thanks in advance!
  • elbolillo
    elbolillo Member Posts: 567
    At the back by the bed. Bathroom. Dinette. And behind the kitchen area.
    pthomas745 Administrator, Moderator Posts: 4,609
    edited October 2024
    This thread has a general rundown of the locations of the various convectors.
    Edit: Sorry, I forgot the link!
    How much time are you giving your Alde  to drive glycol around the various convectors?  It can take a bit of time.
    What temperature are you asking for on the control panel?  The Alde thermostat is snug and warm behind the control panel, and can badly estimate the actual temperature in the cabin. Turn the temperature up.  Get a separate thermometer and see if you need to adjust the "offset" for the thermostat.  (In the Tools menu of the Alde.
    You may need to do some Tab Yoga: but what is the circulation pump speed?  Look over this discussion if this continues to be an issue.
    What is the level of glycol in your trailer?   Low heat could mean not enough glycol in the system.
