I have a 2017 320s. When I follow the instructions for running the refrigerator on propane the flame indicator light stays lit for about 5 seconds then goes out. I tried precooling on dc but that didn’t work. Is this OE?
Running a propane fridge on battery (DC) is running the battery down at a rapid pace, so check your battery state of charge. Try precooling on shore power instead.
There can be many reasons for a propane fridge to be not lighting: from low propane, bad pigtails and regulators, and the fridge itself. There are lots of threads that can help. Tell us what fridge it is.
Carlprs said: I have a 2017 320s. . . . propane the flame indicator light stays lit for about 5 seconds then goes out.
As noted the Fridge Model Number would be helpful 2017/2018 had a mix of the 3160 and N180 which have different lighting sequence/controls
HOWEVER, both do require keeping the Propane Gas Flow (flame size) Button pressed for a few minutes after the pilot lights so the 'good flame' senor comes up to operating temperature (voltage).
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 57Nights: 399 Towing Miles 49,190
