Alde Heat Distribution
AnOldUR
AnOldUR Member Posts: 1,731
On the nuCamp Facebook group there was a post about using a JEGS heater in a T@B. It would not replace the Alde. It would replace the aluminum convectors and change the heat distribution to allow for forced air instead of solely being convection. This sounds interesting to me. I'm considering a variation on this, but was curious of opinions here on the forum.
https://www.amazon.com/gp/product/B07HB9QWHW/ref=ox_sc_saved_title_4?smid=A30XU5Y510T9EB&psc=1
  • RTWCTS
    RTWCTS Member Posts: 203
    115W divided by 12V is about a 9A draw per hour. Do you have the battery capacity to support that? Or is this for when you are on shore power? It can work, of course. These are just my initial reactions to the mod.
    2023 TAB 400 (former T@B 320 owners)
    Virginia Beach, VA
  • AnOldUR
    edited October 2024
    @RTWCTS Most of our time is spent dry camping, so draw on the battery is a concern. The JEGS has a three speed motor with the lowest setting drawing about half that amperage (still fairly high). With the small size of a 320 cabin, the low speed should be all that's needed. Also, it would not have to run continuously. A thermostat in the glycol line might work.
    Actually, looking at that Facebook post had me thinking of a similar concept instead of the JEGS. I've always thought that the convectors under the bed were not very efficient. Not enough of the heat makes it into the cabin. My thought was to eliminate them and only use the convectors under the bench seat. To increase their effectiveness, I'd add a booster fan to the wood panel below the seat. This fan draws less than 2 amps on high and could be set to only run when heat from the Alde is present. My guess is that the forced air would heat the trailer faster than convection.
  • Grumpy_G
    Grumpy_G Member Posts: 740
    edited October 2024
    One of the features of the Alde system is the fairly quiet operation, adding fans will increase the noise level, pretty substantially in case of the Jegs heater (Jegs sells parts for performance cars+trucks where noise is not a major concern).
    The other potential issue is that the Alde system does not generate that much heat compared to a vehicle engine or a home furnace (which is why it takes so long to heat the cabin from low temps). That doesn't change when finding new ways to transfer the heat into the cabin.
  • Mickerly
    Mickerly Member Posts: 486
    With our 320CS the biggest problem is both convectors are covered when the bed is made. I built an extension to the aft vent allowing the heat to get above the mattress. That helped a lot. Then I covered the open areas around the convector box in underseat cabinet with cardboard taped in place. That helped more. Now, it heats reasonable fast and is responsive to changing the thermostat.
    I thought about putting a fan under the bed, but I like the silent heat. Add a light rain on the aluminum top and I get amazing sleep.
    If you don't mind the fan noise, it looks like a good idea.
    2018 320CS-S
    "Just Enough"
  • fstop32
    fstop32 Member Posts: 391
    I placed a 3" x 3" three speed computer fan at floor level and modified the center bench support to be a duct so I could pick up cooler air at floor level and gently push it toward the back and up through the large convector.  At low and medium speed you can't hear the fan at all.  The idea has worked well, still quiet with just a bit of "forced air" movement.
  • Basil48192
    Basil48192 Member Posts: 437
    For those considering either of the blower options above, be sure to check the glycol pressure drop across the new coil(s) as compared to the original design.  I have no idea how much pressure the Alde pump can generate, but it's worth looking into before making a change.
  • AnOldUR
    edited October 2024
    ... I have no idea how much pressure the Alde pump can generate, but it's worth looking into before making a change.
    I hadn't thought about that. The open expansion tank means this is not a sealed system, but the pump does create pressure in the system that could be restricted by the flow through the JEGS core. Definitely something to consider.
    I'm going to try the booster fan method rather than the JEGS. Since it will use the existing convectors under the passengers side bench seat, there should not be any change in flow rates.
    The booster fan came late yesterday and I got a chance to test it out this morning. At the highest fan speed it's pretty loud, but the lower speeds are not bad. The lowest speed draws less than .1 amps, while the boost setting pulls 1.6 amps. My guess is that I will never need to use over the "4" setting that draws a little over .2 amps. Since the fan will cycle on and off, running down my LiFePO4's should not be a problem. These number are through a 120V to 12V power supply. There may be some inefficiency there. When tied directly to the T@B's 12V system power consumption may be a little different. It will be interesting to see how the heat distribution works. Will the highest speed pull too much air past the convectors and be counter productive?
  • Tabaz
    Tabaz Member Posts: 2,421
    A few years ago I extended the Alde loop into the area under the floor to keep the tanks warm in winter.  Five mini-convectors were added in the extended loop under the floor.  The existing pump worked fine with the added piping.  In fact, I kept the pump setting at 2.5.
  • AnOldUR
    edited October 2024
    Sunday project. Finished the fan install. I ran the Alde on electric and the fan seems to distribute the heat well. Hard to be certain with the trailer in the garage. The thermostat does a good job of turning on the fan when the Alde is supplying heat to the convector and turning off when they cool down. We're due to replace the Rhomar this winter. I'll remove the convectors under the bed at that time. Thinking about how to use the space gained for storage.
    We're heading to Upstate New York on the 14th, so it'll get a better test then. Lows will be close to freezing.
  • ybakos
    ybakos Member Posts: 60
    @Mickerly Sounds super interesting, could you share a couple photos, please?
    2022 Tab 320 CS-S Boondock
  • AnOldUR
    Home from that five night Finger Lake vineyard/brewery tour. Temps had water in dogs bowl frozen in the morning. No hookups at any of the five Harvest Host sites. The blower made a big difference in the speed and dispersing of the Alde heat. Also the air movement kept the condensation to a minimum. This may make the top of the list of the many mods done to our 320.
    The only down side is that there in no differential in the thermostat setting. When the set temperature and duct temperature were close it would repeatedly cycle on and off until there was enough of a difference in the two. If I were to do it again I'd look for a duct fan with at least a few degrees of differential or one that was user settable.
  • Mickerly
    I tend to default to simple first. We needed heat above the bed. So, I extended the vent.
    2018 320CS-S
    "Just Enough"
  • Mickerly
    It is a ceda bed slat with two spacers. The cushions hold it in place.
    2018 320CS-S
    "Just Enough"
  • Slackers
    Slackers Member Posts: 491
    I've tried using a USB powered fan under the bed which helps, but isn't nearly as robust or efficient as the ideas listed above.
  • AnOldUR
    Agree @Slackers. I also put a fan under the bed in an attempt to force air up through the back. It worked, but only to a small extent. I was very pleased with how much heat was forced out by the duct fan under the bench seat. Once I remove the rear convectors under the bed and the heat loss there, I suspect it will be even better.
  • AnOldUR
    edited January 2025
    Finishing up this mod and glycol replacement today, but decided to not remove both convector from under the bed. I did remove the outbound one. The thinking was that there would be less heat loss going to the convectors under the bench seat, but I'd still get some heat from the convector under the bed before the glycol returned to the furnace.
    Also, rewired and moved the fan under the bed for better air flow. I had it wired to go on when the Alde pump ran. What I thought was a good idea was not. The fan would run before the heat came up and just push cold air. At the other end of the heating cycle, it would shut off while there was still heat to be moved from under the bed. Now it will only be controlled manually. In reality, it's only needed to heat the trailer quicker when starting from cold. Once the trailer warms up, the convection heating is all that's needed.
  • AnOldUR
    edited January 2025
    This configuration is different than what most of you have ... =)
    A side advantage is that with less plumbing, the total system volume is less than two gallon, so changing out the glycol is a little cheaper.
  • Shadrax
    Shadrax Member Posts: 30
    This works well for us, mounted next to the table bracket and moves the heat down and towards the front instead of up and back.  Also put reflectix on top of the Alde unit because the bed got too warm.  Still trying to figure out the best way to warm the shower/toilet!
  • michaelroyy
    michaelroyy Member Posts: 58
    Can you provide a picture of where you mounted it? How quiet or not, is the fan? Thank you for posting this.
    2015 Boondock
  • AnOldUR
    edited January 2025
    Looks interesting @Shadrax. It could potentially be installed the same way I did with the register booster fan. Like @michaelroyy, I'd like to see how you mounted it. TIA
  • Shadrax
    The fan is very quiet.  I cut a square opening in the vertical “wall” next to the table bracket.  The fan circulates the air from the rear storage compartment under the bed/bench on the passenger side into the main cabin area.  So instead of all of the Alde heat radiating up the rear behind the bed, it moves along the floor towards the front.
