Disadvantages of Removing Outside Trim?
I am looking at a 2020 model 400 that has a couple of pieces of the top trim missing. It will cost $540 to purchase the two pieces and then I have to install them. Is there any disadvantage in terms of water leakage to just remove the remaining trim rather than replacing the missing pieces? Thanks!
  • Pekoe1111
    Pekoe1111 Member Posts: 54
    Also can I substitute some trim insert to fit in the track like the models without the big trim?
  • Pekoe1111
    Just talked with Nucamp and they said no risk of leakage.
    The trim is cosmetic.  So, you can remove it and use something else if you wish.
