Dual MPPT
Does anyone know of a dual solar MPPT charger? It seems like everyone is just adding a second MPPT controller connected to the cabin battery. That seems okay but it might be better to have a single controller.
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
  • ColMagColMag Member Posts: 27
    I don't know of one, but also haven't looked for one. I'd rather stick with Victron, the original supplied one. I added 2 more, and they work well together via Bluetooth. I can see all 3 same time on one phone screen. They talk together with one becoming master and the others slaves, to all be in the same charge mode automatically (bulk, absorption, or float). I added the SmartShunt (500) too, and can also see that on the one same screen.
  • AnOldURAnOldUR Member Posts: 1,676
    You can network the controllers, so they act as one. It's easier and cheaper to add a second.
  • CatDaddyCatDaddy Member Posts: 130
    This really surprises me. I'm an electrical engineer that has designed MPPT hardware. It is much easier and less expensive to add a second channel than to make trackers that communicate with each other to avoid fighting each other. It's almost like capitalism isn't working...
  • elbolilloelbolillo Member Posts: 545
    Victron MPPT chargers are pretty sophisticated devices. I have two installed, and I have never encountered any problems with the chargers fighting each other. The MPPTs, shunt, and inverter all communicate without issue.
