T@B 320 MAX Battery shut off?
Does anyone with an early T@B MAX (one of the first T@B 320 S models) know if there is a battery disconnect switch in the front tub or elsewhere?
I assumed there wasn’t one. Long story, but I picked up my T@B from the dealer and when I got it home, there is no power in the unit she. It is disconnected from shore power.
  • Marceline
    Marceline Member Posts: 1,779
    Not sure what year Pleasant Valley added the cut off switch but I'm pretty sure that they weren't standard equipment in a 2014 model. However, there's a 30A fuse on the positive line that runs from the battery to the house. Have you checked that?
    My 2015 didn't come with one. Adding your own battery cutoff switch was a hot discussion topic in those days. Times have sure changed!  :-)
  • Mellow_Yellow
    Mellow_Yellow Member Posts: 357
    Thanks @ScottG. there is some other issue with my 2 new 6V batteries. It looks like they weren’t connected properly by the RV service tech. I’m getting it resolved now.
