T@B 320 MAX Battery shut off?
Does anyone with an early T@B MAX (one of the first T@B 320 S models) know if there is a battery disconnect switch in the front tub or elsewhere?
I assumed there wasn’t one. Long story, but I picked up my T@B from the dealer and when I got it home, there is no power in the unit she. It is disconnected from shore power.
  • Marceline
    Marceline Posts: 1,767
    Not sure what year Pleasant Valley added the cut off switch but I'm pretty sure that they weren't standard equipment in a 2014 model. However, there's a 30A fuse on the positive line that runs from the battery to the house. Have you checked that?
    ScottG Posts: 5,688
    My 2015 didn't come with one. Adding your own battery cutoff switch was a hot discussion topic in those days. Times have sure changed!  :-)
  • Thanks @ScottG. there is some other issue with my 2 new 6V batteries. It looks like they weren’t connected properly by the RV service tech. I’m getting it resolved now.
