Generator trips breaker
We have a 2022 T@B 400 and a Honda EU2200i inverter generator.  Almost every time we disconnect the power cord from the generator the 40A breaker near the battery disconnect switch trips.  I have tried both removing the power cord and just shutting down the generator and it doesn't seem to make a difference.  Has anyone had this experience?  Is the breaker too sensitive?  Thanks in advance for any suggestions.
    Believe. . .
    Best Patience is to Turn-Off the TAB Power Center Main AC Breaker
    before shutting down the generator
  • I have same set-up with the honda and never once had anything trip when pulling the power cord.  I only make sure the Aldi is off, but even then, if I forget, it has never tripped a fuse either.
    Full-time rving since 2006, tab owner since 2022
