Generator trips breaker
DonF
Member Posts: 25
We have a 2022 T@B 400 and a Honda EU2200i inverter generator. Almost every time we disconnect the power cord from the generator the 40A breaker near the battery disconnect switch trips. I have tried both removing the power cord and just shutting down the generator and it doesn't seem to make a difference. Has anyone had this experience? Is the breaker too sensitive? Thanks in advance for any suggestions.
Believe. . .
Best Patience is to Turn-Off the TAB Power Center Main AC Breaker
before shutting down the generator'18 320 S, pitched axle, 3020HE; PNW based
I have same set-up with the honda and never once had anything trip when pulling the power cord. I only make sure the Aldi is off, but even then, if I forget, it has never tripped a fuse either.Full-time rving since 2006, tab owner since 20220
