Cyclonic
Member Posts: 1,232
This weekend's project; I am adding laminate flooring. I read of someone else doing this, and it seemed like a great idea to solve the problem of the soft floor, which in my T@B is not a water problem.
After talking to Scott Hubble of Little Guy, he told me it is a problem that they are still working on solving. I had thought that the floor is made up of a heavy sheet of plywood, but it is not, it is layers of foam and wood, and it sometimes just has soft spots. Little Guy did reinforce my floor last year with some angle iron, but now it is just soft around the reinforcements.
Happy Trails Y'all
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
Sterling, VA
I laid them crosswise because I liked that look better, I don't think it would matter one way or another.
I had to raise the bed rails because we have a collapsible table that the bed rails simply help support. I also have to raise the benches in order to level out the bed, or there would be a lump from the table part. This was done by placing some of the extra flooring on the support rails under the benches.
All in all, it seems to have been pretty effective.
Sterling, VA
Sterling, VA
Sterling, VA
Well, my weekend project turned out to be three days (result of my not knowing what I was doing), but it's finished except for some touch-ups. I tried to find a floor that sort of matched the countertops with the cabinets as a contrast in between.
Happy Trails Y'all
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Happy Trails Y'all
But wouldn't that be a vote of disapproval?
Happy Trails Y'all
Back to our T@B: finally started reinforcing the floor. I used an aluminum grate material on the main portion of the floor (inside the frame rails), using 1-5/8" Unistrut bolted to the frame rails to hold it tight against the underside of the floor. Found later that the worst spot was immediately inside the entry door, outside the frame rail. I also discovered moisture & rot under the linoleum in the little storage compartment beneath the refrigerator.
Sure looks like water intrusion to me. Have now removed the right front stabilizing/leveling "foot" and have a plan to reinforce the floor in that area, which is outside the right frame rail.
Where's the water come from? My theory right now is the seal between the curved front and the floor, under the aluminum trim strip that runs across the front and goes behind the propane & battery storage area, but I'm really not sure; it could also be coming in around the gas vent for the stove & fridge on the front surface. I really don't want to pull appliances out of the front if I don't have to. (Another possibility is the seal between the plastic fender wells and the floor….)
Ran a small fan in the storage compartment for most of yesterday and it has dried out pretty well, but the outboard forward stud that attaches the leveling foot sits in floor material that's so rotten it just spun when I tried to remove the nut from beneath. I'll have to devise a different system for that one when it goes back together.
Has anyone heard if/how T@B has taken steps to prevent this in the future with new models? I still love that little camper; when we bought our small RV we planned to sell the T@B, but I'm just not quite ready to part with it!
My DW was eyeballing those Mercedes 'campers' before we got the Tab. The badge on the grill convinced us we couldn't afford it
How's the build quality, compared to the Tab? Appliances any different, etc?
Happy Trails Y'all
