I am installing a lithium battery and need to disconnect the solar to get the converter to switch to lithium properly. Is there a simple way to disconnect the solar? Is there anything special I need to do with the solar panel while disconnected? Thank you all for the information!
0 ·
Install the 30A DC Circuit Breaker on the red "+" PV wire between the solar panels and the charge controller. Use the red button to disconnect the solar panels, and the blue lever to connect the solar panels.
So to reset in the right order:
1. Disconnect the solar panels by hitting the red button on the 30A DC Circuit Breaker, then turn the master battery switch to off.
2. Turn the master battery switch back on, then swing the blue lever on the 30A DC Circuit Breaker to connect the solar panels again.
On a side note, if the thought of completely disconnecting the battery makes you cringe, it is possible to add a second 30A DC Circuit Breaker to the "+" Power wire on the charge controller. This way you can do both steps from the same place.
PS, credit to Paul Thomas over at the Tab 320 Campers page on Facebook he is an incredible resource.
HTH
https://www.amazon.com/dp/B0DC3YM1NL?psc=1&ref_=cm_sw_r_cp_ud_ct_BJSPSKYRDP0T86BW3MTX
https://revkit.com/donmontalvo/ | https://donmontalvo.com
