Overhead fan
hikerchick
Member Posts: 35
I just went out to check on things and noticed my ceiling fan isn’t working. Any ideas? I checked the fuse it doesn’t seem to be blown. Haven’t used it very much and always careful with it while using it and when towing.
If you are on shore power: is the fan cover open? The cover has to be open a certain amount for the fan to begin to spin.If just on battery power: are the lights or other 12V items working? And, also, the cover needs to be slightly open.What fuse did you check? There is one in the converter, which in most of the WFCO diagrams is the first fuse on top of the other fuses: a 10 amp fuse. If the fuse is blown in the converter, there will be a red light next to the blown fuse.There is also a fuse on the Fan itself: it is held into the fan housing with the little round "knob" looking thing. It is a 4 amp fuse, so it might be worth a look at it, too. This is the Fuses For Newbies file, with various pictures and descriptions of fuses that will show you where that fuse is located.
Towed by 2014 Touareg TDi1 -
The other thing that caught me once was the fan cover not being raised sufficiently. There is a switch there as well.
Thanks guys we checked both fuses. I am on shore power and my cover is opened. Just wanted to make sure that there was anyone that had anything else to cause it not to work.0
What year is this trailer? Some of the newer fans have had issues with various "motherboards" and switches in the fans.There are lots of threads about the newer models of Fans that simply had failed circuit boards.Some of the MaxxAir fans also had issues with this sort of thing.
I have a 2018 400 and both fans stopped working. Fuses look good. Wiring issue perhaps?
2018 Tab 400 towed by 2013 F150
Evanston Wyoming home0 -
If both fans stop at the same time I would test the fuse as they are on the same circuit in the 2018 I believe. Or just replace the fuse as sometimes they can be bad and look OK.
I agree with @qhumberd check the Power Center fuse with a meter or just replace as it is the most likely cause of both fans not working.
Reference wiring {fuse # position can vary}
Adventures: 61 Nights: 417 Towing Miles 51,0500
