The Norcold fridge in our 2018 320 works great when connected to shore power. When operating on propane, it lights nicely and appears to be set to operate well, but it is just not getting cold. I can feel some heat exiting the exterior vent. The trailer is level. The outdoor temperature is mild. The propane tank was recently filled. Any advice to determine the source of the problem and rectify it?
I’ve read the many Norcold posts on this forum, but have not seen a discussion on the scenario where the fridge works fine with shore power, but not with propane (even though it lights). Thank you.
Unfortunately I can't advise on checking the burner, as I have never been faced with this issue (and I was really just guessing). I know some others have worked on their 3-way fridges and will hopefully chime in here with some solid advice.
I found the following on my ipad under files. First author is unknown IGNITION – PROPANE GAS OPERATION
From Jenn Grover:
2018 Toyota Highlander, XLE
Wisconsin
