Is the dealership trying to screw me?
Hi Nucamp friends,
I'm looking for advice from the community before I take my 2022 TAB 400 BD Edition back to the (NuCamp recommended) dealership tomorrow. Last October I took it in for leaks that would occur every time I turned the water pump on. The leaks were coming from a couple pipes (connected horizontally) to the back of the Nautilus panel in the under-bed compartment, as well as a leak from behind the toilet. I discovered the leaks after following the de-winterizing/powerfilling/dry camp-mode'ing video NuCamp has on their Youtube channel.
The day I got the camper back, I had a family emergency come up and ended up having to quickly drop the camper off at it's usual spot before leaving the state to take care of a sick elderly parent; I only just got back a week ago and after filling the fresh water tank (to 3/4 full from nearly empty) discovered the leaks are still occurring in the same areas previously mentioned.
I called the dealership and told them the situation and they asked whether the camper had been in storage (no, I had it outside) and whether it was winterized (it was not). The dealership guy said the leak was likely caused by the fact that I hadn't winterized it and didn't store it away from the elements. So in other words, they want me to foot the bill for all upcoming repairs.
However, the indicators for the water tanks were at the lowest possible readings, and though there might've been a small amount of residual water in them, I question whether the leaks are due to the quality (or lack thereof) of their repair services. When I picked up the camper and did a walkthrough, they hadn't even put the wooden cover back on over the Nautilus compartment.
Key sidenotes: I live in the foothills of Colorado (at about 5k feet) and though I wouldn't have had time to do it anyway, I was not planning to winterize because the previous owner (an engineer) did a custom 'winterproofing' job by installing insulation (among other things) underneath the camper - just above the exterior bottom-most layer of the camper. He said he had lived in the camper with wife and kid for 2 months the previous winter with running water and seems like a truly honest guy.
I am questioning the dealership's stated complete lack of fault for the pipes leaking. One of the two leakyy spots I found is in the nautilus compartment at the connection points directly behind the nautilus and are situated horizontally. Since my tanks were presumably almost empty, it seems unlikely that water would have pooled up in those pipes.
Of the two pipes leaking in the under-bed compartment, one of them is leaking at the same coupling as the original leak, the other from the coupling in the pipe just next to it. These are the first points of contact coming from the back of the Nautilus. The leak in the bathroom is from the same leaky coupling connected behind the toilet that existed prior to their repairs.
Now, I admit I am no plumber, but I am reasonably handy. Seemingly the only thing that prevented me from making the repairs myself was the fact that I could not access the leaky pipes with a PEX tool (due to the lack of space around all the other pipes behind the Nautilus) without taking everything apart.
So my question to you all is: should the dealership bare some (or all) of the responsibility for the leaks, since it seems to me like they might not have fixed it properly in the first place - OR - does it seem more likely the leaks were caused by my lack of winterizing and indoor storage?
If you made it to the end here, thank you for reading! Any and all advice, thoughts, and questions welcome.
  • Grumpy_G
    Grumpy_G Member Posts: 712
    You're not going to like this but you can't blame it on the repair work. If you you had discovered the leaks a few days after getting it back you would have a case but after letting the trailer sit not winterized they have an easy way out.
    Assuming they did the repair and tested it the water lines would be full of water regardless of how much was left in the tank. The additional insulation does help with heat loss when camping in the winter but it would need the heater to run to prevent lines from freezing. The PEX tubing itself survives freezing because it is flexible but the hard plastic fittings do not that's why the leaks are at the connections.
  • Mobean
    Mobean Member Posts: 74
    I'm afraid I agree with Grumpy_G.  While you may be correct about possible subpar repair work, the information provided doesn't give you much to stand on.  Hopefully, the dealer will cut you some slack and provide a bit of a discount in the spirit of good business (which would pay them back much more in the long run).  Get the problem fixed and take this as lesson learned.  Don't let this experience take away the enjoyment you will get from your T@B.
    2021 320S BD
    2020 V6 Chevy Colorado
  • scott14
    scott14 Member Posts: 189
    Sorry to say, but I tend to agree with the previous posts.  I would add that if they fixed the leaks, charged the line with water to verify their repairs and the unit was not then subsequently winterized, I would be concerned that there may have been water in other areas of system that froze.  For example, the residual water in the pump and filter.  Water is not easily drained via gravity from those locations.  It would be worth investigating yourself to see if other issues have developed.  As mentioned, I hope this does not take away from all of the adventures that are ahead of you!  Keep us posted on what you discover.
    Scott / 2019 T@B 400 "C@lypso" / 2015 Chevrolet Tahoe LTZ / Northern Illinois
  • Cherokee
    Cherokee Member Posts: 346
    Living in the trailer in the winter the previous owner probably ran the heating system and the added insulation assisted keeping the heat in the trailer. However, with no heat in the trailer while setting outside, the added insulation would simply slowly become the same temperature as it was outside. Water is interesting in that it expands as ice crystals form - this is what cracks and breaks pipes. Unfortunately, even residential water at any low point in the system can produce damage.
    California, USA
  • Horigan
    Horigan Member Posts: 864
    The original leaks were likely caused by not winterizing, so they would fail in the same locations again in freezing weather after the repair...
    Rich
    2019 T@b 400
    Bellingham WA
  • rfuss928
    rfuss928 Member Posts: 1,181
    edited January 2025
    Tiny worm drive clamps can be used in place of the crimped clamps on PEX fittings in most cases.  This can be helpful servicing work with difficult access or when PEX clamps and tool are unavailable.
  • elbolillo
    elbolillo Member Posts: 549
    Chiming in on the use of worm drive clamps mentioned by @rfuss928
    After doing my winterizing, I noticed that I had at the connections between pex fitting and the flexible PVC tubing I had leaks. It is next to impossible to use a crimp tool to tighten them down. I removed most of the PEX crimped clamps at most of these connections and replaced them with stainless steel worm clamps.
    The difference in the quality of the connection is night and day difference. With the crimp clamps I could twist and move the PVC tubing. With the worm clamps they are nice and snug.
  • Cherokee
    Fuel line clamps - I have better luck with this type of clamp
    California, USA
  • andytabrv
    andytabrv Member Posts: 40
    I found this video recently and it seems to reinforce the experience you are describing using the clamps for the flexible hoses.
    https://www.youtube.com/watch?v=YPQ_aTOW5xw
    2022 Nissan Pathfinder
    Cary, North Carolina
  • Cherokee
    Please listen to what he is saying - it's not the only the clamps, but the type of hose & fittings used with the  clamps. These are images of my T@B  with NuCamp's original plumbing instillation of hoses, fittings and clamps that have never failed or leaked after 5 years in-spite of cross country trips and several rough dirt roads
    If someone has to work on their plumbing with the correct fittings and hose, I'd recommend the fuel type clamps that I've used to replace the screw type clamps on my Jeep that I wheel on 4x4 trails because they stay tight where the screw type has lessened.
    California, USA
  • Binghi
    Binghi Member Posts: 403
    How do you loosen them in case you want to replace the hose? They looked permanently crimped.
  • Binghi
    look permanently crimped
  • Cherokee
    Ask any trailer tech who owns a screwdriver to pry the tab and pry it open against the spring
    California, USA
