I'm brand new to the forum and to towing. I'm in the process of buying a used 2022 TAB 320S. I plan to tow it behind my 2023 Volkswagen ID.4 Pro S Plus AWD electric car. It is a so-called BEV (Battery Electric Vehicle, meaning it has no other power source than the battery). It has a towing capacity of 2,700 when towing a trailer with brakes. It has a factory connector for connecting an electric brake controller.
I'm wondering if anybody has towed a Nucamp teardrop behind their EV. I'd love to hear what their experience has been like, what TV they're using and what brake controller they have.
The current plan is to buy a Curt Triflex NEXT brake controller (Curt PN 51146) and the vehicle specific wiring harness (Curt PN 51528). I chose this solution mostly because it is the only plug-and-play option I could find.
Does anybody have any advice?
2022 NuCamp T@B 320S Boondock
We have done about 4 or 5 trips after buying the T@B in early July and find that efficiency is cut in half and our safe range is around 100-110 miles between charges, traveling at 60 mph. Weather and wind are factors that can cut that a bit. The charging map is slowly but constantly being filled in and we've had no trouble being able to charge when needed. We choose campgrounds with 30 and 50 amp service and are able to use a portable Level 2 charger to connect to 50 amp to charge overnight. There are some campgrounds that don't have sufficient electric infrastructure to support this but by and large we find that most are robust enough. Some have even anticipated EV campers using their campgrounds and now charge a modest fee like $15 - $25 to charge. After a day of driving involving charging stops it's nice to get in a free or very inexpensive full charge overnight.
I bought and installed a Tekonsha Prodigy RF brake controller that is mounted on the camper tongue frame. The camper wiring plugs into one end of the controller unit and the unit's wiring cable then plugs into the Kia's 7-pin outlet. A bluetooth handheld control plugs into a standard 12V cigarette port in the car's dash and communicates wirelessly with the control box on the camper. The handheld device allows for setting gain (camper braking power) and has more forceful override settings for harder braking if needed. So far the unit has functioned very well. One nice aspect is that any tow vehicle can tow the camper as long as the driver has the handheld control which can be synced to the required gain setting for that vehicle. Right now my son is on a trip towing with his Rivian.
2024 Kia EV9
We use the Curt bluetooth brake controller with the Y, the included one with the Ford. Regen does 99% of the braking.
Also be sure your campsite has 50a service, that way you can charge your EV while at the campsite and leave at close to 100% if you need to. 30a won’t cut it because it is 120v and a mobile charger won’t do more than 12a at 120v.
I have not had any issues at State Parks. I plug the 50a in for the EV and the 30a for the camper at the same time and turn down the charging amps to 25-30 if the EV has that option.
I have heard KOA has said no to charging EVs, but we don’t stay there. I think a charge for charging is reasonable but most non-EV people think you are using way more energy than you are. It should be a max $20 fee for trucks and $15 for cars.
With enough practice you'll develop a routine for unhitching in order to charge if that's necessary, which is probably more often than not. You'll quickly learn the step you need to take to unhitch and later hitch up. The charging stops are good times to eat something, use restroom facilities, enter your next charging destination in the car's navigation and take a minute to take note of Plan B chargers just in case. Charging stops are not a waste of time.
At campgrounds that offer both 30 and 50 amp service you'd plug the camper into 30 amp and your portable Level 2 charger into the 50 amp outlet to take advantage of its 40 amp output. I guess it's debatable whether you should announce when entering a campground that it's your intent to use 50 amp service to charge overnight. I'd like to think that the one owner who bristled when asked is an outlier. I've never seen that reaction. Some staff recognize the EV and will tell you what their policy is and whether a fee is due to charge.
Here's what I found regarding your Curt's gain and load settings:
"The GAIN setting on the Curt TriFlex NEXT Trailer Brake Controller # C24VV has to do with the max "strength" of the brakes, while the LOAD setting is how aggressive the brakes get to that GAIN setting.
So, to simplify things, GAIN is the braking strength while LOAD is how quickly the brakes get there.
Since everyone has different preferences in how their trailer brakes perform there aren't any hard and fast settings for different truck/trailer combinations. The best rule of thumb to go by is to put the settings in the middle and then drive around an empty parking lot to test how the trailer brakes perform and adjust them to your liking."
2024 Kia EV9
2024 Kia EV9
When you refer to your charging cable, are you referring to your portable Level 2 cable to be used for charging your EV? It would plug into a campground's 50 amp 4 prong outlet similar to this:
If your portable charger has 4 prongs you're all set. If it has 3 prongs, as mine does, you'll need a 3 to 4 prong adapter like this:
The 4 prong plug goes into the campground 50 amp 4 prong outlet. I hope all this is clear.
2024 Kia EV9
Edit: You're right, your ID.4 tow limit of 2700 lb. is just about the dry weight of the 360 and also under the dry weight of the even heavier 400. You'll need a TV with at least a 5000 lb. limit to handle either one.
2024 Kia EV9
Sounds like your EVSE, with its 4 pin adapter, is ready for EV charging at a 50 amp campground outlet. The adapter in the photo I posted is for 50 amp transition from 3 pin EVSE plug to 4 pin campground outlet. Apologies if I confused you.
2024 Kia EV9
When you plan to stop at campgrounds on a trip, check their websites to see if some spots they have are 50/30/110V to see if you can reserve one, or just show up and take your chances if you hope to charge the ID.4 overnight.
2024 Kia EV9
2025 Ram 1500 “MTFLY”
2025 Tab 360cs (in production) “Honey Pot”
”Honey attracts more flies than vinegar”
Relentlessly Pursuing a 2025 Silverado EV
Racing the Wind and Chasing the Sun
Virginia Beach, VA
Virginia Beach, VA
