I have a 2023 320 Boondock and would like to improve its capacity for boondocking 3-5 days. It currently is stock (12 volt lead acid, roof solar panel, Victron controller). I have a generator but would prefer to limit its use. What would be the best setup to use? I am considering 1) two 100 amp lithium batteries 2) 100 amp lithium battery with portable solar panel to make sure I can get the battery topped off each day 3) 100 amp lithium battery with a portable power bank with solar for supplementing the lithium battery each day or occasional use to access regular outlet use.
Do any of these setups require additional modifications or are they pretty much plug and play? Other than changing settings on the Victron and converter, are there any additional steps needed? I am not the most handy when it comes to electrical systems so I am looking for the easiest upgrade. Any and all feedback is very appreciated!
0 ·
On longer trips, we do carry a 700W propane generator for charging just in case solar falls behind, but it has never been necessary to use it. Since we store our TAB inside, before leaving on a trip we'll top off the batteries with a lithium compatible charger that's also mounted in the tub.
I'm not an electrician and was able to accomplish this setup. With a bit of patience and care you'll be able to get it done.
Power bank is inefficient and costly. Better off adding a second battery.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
John, Northern California
