I have a 2024 nuCamp T@b 320S Boondock Black Canyon. It came with a single 100ah Battle Born battery and no inverter.
I am planning to add a second
matching battery in parallel. I an attaching my diagram draft (if I make any changes I will update the image and date it here).
I feel confident the components are ok. But I have a few questions:
1. Where can I run the new ground busbar to? There is a busbar on the opposite side of the trailer but it is wholly inadequate for this new battery design. The largest wires connected to that existing ground busbar is 10 AWG whereas I need a place to ground a 1/0 (0 AWG) ground wire for the attached design.
2. I hate to duplicate efforts, so anyone know if there is a document that lists power consumption for all the DC powered stuff that came with the 320S? This will help me calculate wire size to provide the safest AWG. Currently the diagram shows 1/0 (0 AWG) which I hoped would cover things, but I wanted a sanity check.
3. I have a new Victron Phoenix 1200W inverter standing by, so I will add that that power info to any list that may exist.
DISCLAIMER: I am collaborating on the Victron Facebook page, where many of their employees and expert installers hang out…these questions are out of scope for that forum so posting here.
TIA
Don Montalvo | Retired Veteran | Full Time Snowbird
2021 Jeep Wrangler Unlimited Rubicon
https://revkit.com/donmontalvo/ |
https://donmontalvo.com
https://revkit.com/donmontalvo/ | https://donmontalvo.com
Here is a load sheet that another TAB user put together. I added the Air 8 number (compressor running) based on an experiment I conducted when I installed my inverter.
In regards to your first question, when I installed my inverter (2000W) and used 2/0 wires for the inverter/battery circuit, I did not run a 2/0 wire to the ground stub from the negative busbar. That could be wrong, but based on the research I did. I ran 8 AWG. I followed other inverter installs and do not recall seeing anyone doing that. I believe, if I remember, the rationale was because the DC loads in the trailer were not changing. But I'd be interested to hear what others with more electrical knowledge would say.
Southern Maryland
Southern Maryland
I have the inverter sitting on the side, ready to go, with 1/0 wires and a 150A circuit breaker on the positive wire. Waiting for the stuff in the diagram to be completed.
I am not sure yet if I will connect the inverter’s wires to the positive and negative busbars…or the positive to one battery and the negative to the other battery…or connect to the positive on one battery and the negative to the busbar. I figure that will be part of the next phase of work.
Southern Maryland
