Hi,
We saw a 360CS today at the Philly RV show. It was the a Boondock version (not full lithium package). Just want to pass onto others the location of the battery which is located in the bottom drawer below the counter. Have to give it some thought of how to add a second battery and/or inverter which we have in our 320. An inverter could fit in the lower drawer the right. A second battery not so sure yet. We are moving forward with our purchase, but will have to figure this out. We like the convienance having an inverter to use microwave, hot water pot or other AC electrical devices for a few minutes when there is no power.
The 360 S has the battery below the passenger side bed at the rear.
Southern Maryland
I'm guessing there is not room under the rear bench for a battery, like in the 360S, because of the space the outdoor kitchen takes in the rear. The Truma Saphire is in the back below the bench.
Southern Maryland
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
A quick update. I contacted Nucamp of where extra batteries could be located inside a 360CS. They pointed me to a storage location under the driver side bed. Another CS owner (who has taken delivery) also told me of this empty storage area that matches what is found in the 360S (shown in picture). Not sure why they selected the drawer, other than maybe with all the available storage in a 360, the drawer was selected over the larger compartment under the bed. Anyways, it's good know there is plenty of space for a second battery and an inverter for a 360CS .
Southern Maryland
And if I remember correctly, I believe the battery is under the passenger side rear seat area on the regular 360. Does anyone have a picture of that compartment on the regular 360? I know @Gomers2 posted some pics of that area when he was repairing the seat, but not one of the battery compartment.
Perhaps when you get your 360 CS and have time you could provide some additional photos of where all the equipment lives.
The battery location change probably has to do with the design required in the rear for the outdoor kitchen.
I can see perserving the larger space on the side if needed by the user.
The CS model is 16" longer over all. Everything inside is the same.
Someone who just took delivery of a CS is suppose to send me pictures.
It's fine with us...we go out for months at a time don't even use all our indoor space in our 320. I'm just happy there is room and it will be easy to add two batteries and in my case an inverter. Was not interested in the lithium package as I can easily put in almost the same capacity for more than 1/2 the price.
Southern Maryland
From Nucamp:
"The Victron MultiPlus inverter/charger is installed on the inside of the under the bench seating. The 270amp Battle Born lithium battery is installed on the underbelly on the outside of the unit close to the axle, you would have to remove a panel to access"
To each their own I guess. I may want to switch out the latch though, so it's not the same as the other drawers - and I agree the positive terminal looks kinda over-used.
That location is not really a "kitchen" in the CS the same way it is in the standard. It is more of a storage area.
I only think it is weird that it is set up and presented as a normal drawer - so clearly just reusing the cabinetry from the standard in this regard I think.
I am first installing my surge protector for shore power, and then I will figure out more future plans.
Biggest thing I immediately want to prevent with the drawer is people always opening it to see what is in there - like I don't want those wires and connectors moving more than they need to.
So until I get it done, there will be blue tape over that latch with a "do not open" label.
Southern Maryland
@Yoshi_TAB, are you planning to move all batteries and related components to that compartment (under driver's side bed)? And are you adding a battery? Really, with the large fridge inside and the one out back, I think 100ah is underpowered.
Yes, that’s my plan. But until I get the CS and see what access to wiring is available, don’t know for sure. Need decent access from the WFCO and 30 amp outlet romex cable. I have an automatic transfer switch in my 320 and really like the convenience. May just go with a multi plus depending on space , access to wiring, etc.
Southern Maryland
2022 320 CS-S Boondock
2015 Honda Pilot
Are you picking up a '25 or '26 360CS. If a '25, someone posted on the 360FB page a picture of two battteries inside the lower cabinet where the single battery is provided. I was surprised they could fit. Just want to pass on as an option. I'm not totally sure but I believe the '26 CS battery location was moved to somewhere under the dinette. I have not seen a photo. I moved my battery in my '25 CS to the rear behind the AC where non CS battery location is found. Two batteries will certainly fit under the drivers side bed or behind the AC. The under bed storage is hard to give up...IMO. Best wishes with your 360.
Southern Maryland
2015 Honda Pilot
