Cleaning the outside of Tab 400
Our 2023 white Tab 400 Boondock has gray streaks coming down from roof front and back.   After several washings (including washing roof) the streaks have lightened but are still visible.   Afraid to use anything harsh for fear of damaging the paint finish.   Has anyone else had this problem and solved with a certain product?
  • marleecampsmarleecamps Member Posts: 167
    I have had pretty good luck with this product.  https://a.co/d/fTcYYUC
    --Marlee
    2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
  • BaylissBayliss Member Posts: 1,477
    @Ma_Pa, have you tried waxing it?  I have used Mequiars Cleaner Wax since I purchased my trailer and it continues to look like new.  It should help with removing streak marks, as well as oxidation.  I wax my trailer at least once a year, but often twice.  I have had the same results with my tow vehicle and car.  They have always looked new, regardless of age.
  • MickerlyMickerly Member Posts: 465
    The cleaner wax should work great. I use the same one. Once it is clean, there is less work keeping it clean by using a "polishing wax." I use a silicon based wax. They appear to last longer. The sides will last all year. The top gets a coat every other month.
    2018 320CS-S
    "Just Enough"
