Strongly considering a sway bar on our new 2025 Tab 400 Boondock but concerned about the large storage tub on the '25's interfering with installation. The want you to install bracket on frame back 24" and that is dead under the storage tub! Anybody have experience/advise on sway control on the newer Tab 400?
0 ·
John, Northern California
Southern Maryland
I also recall that the frame on our trailer was not considered suitable for weight distribution bars, so I wonder if sway bars are a similar concern. So my advice would first to be certain that you actually need the sway control for your setup.
nuCamp does place restriction on the ratings for a weight distribution hitch due to the construction of the frame, but they can be uses. The weight on the ball should be 10% to 15% of the loaded weight of your trailer. If you are within this range and still experiencing squat much greater than an inch in your suspension when you attach your trailer you should consider using a WDH. If not a simple friction sway bar can be beneficial.
