Tab 320 Awning
GalaxyGalaxy Member Posts: 1
I sold my Tab 320 so I no longer need the awning, it’s a very heavy duty material, I used it on my 2007 and 2020 year models 320, not sure who makes the awning but it’s in great shape no holes or tears, all aluminum poles are in great shape, carrying bags included. $200.00. OBO,  I can ship at your cost or pick up in Little Rock Arkansas. Thanks John
bondiesel@sbcglobal.net
  • rfuss928rfuss928 Member Posts: 1,048
    edited March 16
    FWIW - The pictured set up in the OP is incorrect:
    1 - The front arch pole curve should match the trailer roof line.  It needs to be swapped front to rear.
    2 - The two poles shown supporting the arch are actually two more stretcher poles and need to be installed in the bottom of canopy in the sleeves front and rear.
    3 - The bottom of the arch pole should be about the same width of the trailer body.  Twelve feet per the manufacturer instructions.  It appears much too wide in your photo.
    OEM awning instructions attached - There were some changes to the stretcher pole design over time but the basic layout and setup remained unchanged.
    Our original "flower power" version installed on our 2009 T@B CS
    And now, 16years old, installed on our 2023 Ultimate Toys CSS
    Very durable and sturdy.  Remains stable in strong breezes if front corners are staked down.  No guy lines needed.
    Highly recommended for anyone considering this style awning
    Good luck with your sale...
    Bob
